Home > Maintenance & Modifications > 13 pin towing electrics installation
Page 3 of 3 <123
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I know its a bit late to add this info, however;
13 pin electrics kit part no's:
TD5 vin 1A000000 on - YWJ500050
TDCi 2007 on - LR005919
On the Puma kit the only wire going to the battery box from the socket is for the switched 12 feed, all the lighting feeds are picked up from the socket at the rear.
Post #522440 9th Apr 2016 10:55am
Dasher
2015 Defender 110 Puma 2.2 USW Santorini Black
Thanks. I'm on the later 2.2 (2015) and have the .....050 kit. Yes, picked up the lighting no problem but the reversing light pickup is still as described in the OP post (at lease the 050 kit has all this. I'll hook up to the van and see if I have reversing lights from the multi socket under the rear protector - guess that should tell me.
Post #522443 9th Apr 2016 11:03am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
A bit(!!) of a thread resurrection...
Im fitting a trailer socket (std LR socket/wiring loom/connector) to my 2001 TD5 HT and want to fit it in the recess in the rear cross member.
However, there is a square cut out behind the recess but behind that there is a round hole. The LR connector wont pass through the round hole.
Before I disconnect the wires from the 7 pin socket, is there another route to get the wire through the cross member to the trailer connector in the rear wheel arch..?
A couple of photos
Post #1018142 12th Dec 2023 12:06pm
No, there isn't. This is classic recent Land-Rover "design", to provide a purpose-built recess for the socket, then sell a socket kit that cannot easily be used with it! Doh!
It may be easier to remove the connector inserts from the shell in the photo rather than remove them from the 7-pin socket (sometimes the 7-pin end is "potted" with a dielectric potting compound).
Post #1018146 12th Dec 2023 1:00pm
couplands
Thanks for the reply.
I have managed to get the square connector through the round hole....just. Then it hits the back of the fuel tank....! However, with a large screwdriver and not a little force I managed to get it through. I didn't fancy taking the pins out of the socket, I've done that before and it didn't end well.
Anyway, its done now. The next issue is to find my rivnut gun....Wink
cheers
simon
Post #1018147 12th Dec 2023 1:13pm
Page 3 of 3 <123
