Home > Maintenance & Modifications > Oil for gearbox - transfer case - diferentials
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Hi
What is really the recomended oil for:
Geabox (new 6 speed)? (sintethic 75W90 or automatic transmission fluid????)
Trasfer case (of the new 2.4 6 speed)? (sintethic 75W90 or mineral 80W90?????)
Differentials (also or the new 2.4 6 speed)? (sintetehic 75W90 or mineral 80W90?????)
I in the manual, gearbox and diff's are sintethic 75W90 Smile , only the transfer case don't have any recomendations in the manual Mad , but I think that I can use also in the transfer case a sintethic 75W90 Question
regards!!!!
Post #11337 27th May 2009 5:47pm
Stephan
Namibia 2008 Defender 130 Puma 2.4 HCPU Alpine White
Gabriel,
From the GTR, the gear box fluid is as such:
Item Specification
Manual transmission fluid WSD-M2C200-C
Super DOT 4 brake fluid ESD-M6C57-A
Sealant WSS-M2G348-A10
Grease ESD-M1C220-A
Capacities Litres
MT82 transmission - Initial fill 2.4
MT82 transmission - Service fill 2.2
From the GTR, the transfer case fluid is as such:
Item Specification
Recommended oil API GL4 or GL5, MIL-L-2105 or MIL-L-2105B
Capacity 2.3 litres, (4.0 pints)
CAUTION: Do not use any lubricant other than that specified General Specification - LT230Q
From the GTR, the rear differential fluid is as such:
Item Specification
Final drive * Molytex EP90
* Do not use any lubricant other than that specified
Unit Capacity
Differential - 90 Models 1.70 litres (3.0 pints) (1.80 US quarts)
Differential - 110 Models 2.26 Litres (4.00 pints) (2.39 US Quarts)
From the GTR, the front differential fluid is as such:
Item Specification / Land Rover part number
Final drive Molytex EP90
Swivel pin Molytex EP90 OR 80
Item Capacity
Front differential 1.70 litres (3.00 pints) (1.80 US quarts)
Swivel pin housing oil/grease (each) 0.35 litres (0.60 pints) (0.37 US quarts)
If you need more let me know i will check in the GTR for you.
Stephan Stephan
Meiring II - 130 Puma 2008
Meiring I - 110 200TDI 1989/1991
Post #11483 2nd Jun 2009 9:05pm
