Home > Puma (Tdci) > Realistic fuel tank capacity
Page 3 of 3 <123
Naks
heinrichnel wrote:
This weekend I managed 118 liters into my 110 with an extra fender tanks, I was under the impression the capacity was 120 Lt? Now not so certain. And no limp mode with according to what I know 2 liters left in the tank?
It doesn't limp. What will happen is that the engine will hiccup. IIRC then it will switch itself off in a couple of kms to prevent the engine from running out of diesel completely. --
Post #163959 23rd Aug 2012 3:12pm
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
i hate filling up, (cost and time) so i always aim to do another 30 miles after the bong in my 2.4tdi 90xs.
when my my 51 plate c class was running really low, hard cornering used to starve the engine of fuel and it would temporarily run out until it was travelling in a straight line again.
Post #163975 23rd Aug 2012 4:12pm
ZeDefender
Why do I get the impression we don't use our vehicles "normally"? Laughing Tell someone you love them today because life is short.
Post #163976 23rd Aug 2012 4:13pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Quote:
How much useable fuel is left after the "beep"?
I can't find it in any LR texts.
Probably more than we think I reckon, I managed to do 69 miles (to a filling station) in a d3 after the trip (trick) meter said 0.00 miles range on remaining fuel! The garage I was going to go to was blocked off on the motorway and couldn't go elsewhere as we were boxed in in a huge traffic jam. A bit of slipstreaming and hardly any throttle seemed to work (maybe I'll try that in the 110 when I have nothing better to do Thumbs Up )
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #163985 23rd Aug 2012 5:04pm
T5bnc
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
in the words of Robin--- holy thread retrival batman!!!
Ive a 59 110 XS and get 350miles at best when the ping come on!!!!!
Post #187157 22nd Nov 2012 1:37pm
Tiger
Really?
Post #316630 17th Mar 2014 5:15pm
david110
Scotland 2015 Defender 130 Puma 2.2 HCPU Santorini Black
I have a DC 110 and I'm returning 25mpg no matter how you drive, I have had it from new and have been keeping a close eye on the consumption as its been my first new buy ever so was keen to see how things went. According to my phone app I have spent £6,500 on diesel and I get 24p to the mile.... I dont care to much its only out of interest as I could as easly buy a car that did 74mpg but it wouldnt ba a Defender and most probably wouldnt do what I wanted.......... My son also owns one a TD5 defender and my wife drives Discovery 4 so we are an Land rover family.
Happy Defenders all round
David
Post #318562 23rd Mar 2014 11:21pm
leealanr
2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Managed 800 plus kilometers for 101 ltrs in heavy traffic use in Addis. Tank is 120 litres. Darent run the tank to low and use only one source for fuel where possible. Dont want to even think about getting into limp mode outside of the city.
Post #320982 2nd Apr 2014 8:58am
Grey110
Netherlands
The WSM says:
Fuel tank usable fuel
90 Models ............................................................... 60.00 13.20 gall
110 & 130 Models ................................................... 75.00 16.50 gall
What I understood is that the real fuel tank capacity is 5L more because you should not use the last 5L. That's why it says useable.
Martin Martin
Previous 2003 Defender 110 Hardtop TD5
2004 Defender 110 Station Wagon TD5 - Libyan Sand
2005 Discovery 3 - V8 - Black
Post #321111 2nd Apr 2014 8:24pm
Lou Sparts
I am sure when the Td5 90 was launched the fuel tank capacity was stated as 67 ltrs, not sure about the 110. 2005 Td5 90 XS
Steve
Post #321123 2nd Apr 2014 8:57pm
shaggydog
If you have a metal tank in a 110 its 80 litres Cool
Plus an extra 2 if you fill it up the neck Whistle
Post #321127 2nd Apr 2014 9:09pm
Grey110
Netherlands
Idea Embarassed My TD5 numbers are not completely relevant here, although the fuel tank is the same Question
Luckily I am a WSM collector Laughing
TD4 2.2 WSM says:
Fuel Tank Capacities
Variant Capacity (Useable Fuel)
90 55 liters
110/130 70 liters
and:
LOW FUEL INDICATION AND RUN DRY STRATEGY for 2.2L MY2012
The run-dry strategy is used to maintain the systems fuel prime at fuel run out. It ensures the minimum amount of fuel is always left in the swirl pot.
The instrument cluster activates the yellow low fuel warning light (next to the fuel gauge) with 17% of fuel remaining in the tank. The fuel gauge will indicate empty with 12% of fuel left in the tank.
With 6 liters left in the tank the run-dry strategy will be invoked. An engine mis-fire will be induced for approximately 1 mile after which the engine will be shut down. The engine can be re-started in mis-fire mode and will continue to run for a further mile until the engine shuts down again. This can be repeated until the fuel suction port in the tank is uncovered and causes engine fuel starvation and loss of prime. Re-starts after run-dry shut down are not recommended.
For 2.4L MY2007 it is:
The instrument cluster activates the yellow low fuel warning light, (next to the fuel gauge) with 15% of fuel remaining in the tank. The fuel gauge will indicate empty with 11% of fuel left in the tank.
With 4 liters left in the tank the run-dry strategy will be invoked. An engine mis-fire will be induced for approximately 1 mile after which the engine will be shut down. The engine can be re-started in mis-fire mode and will continue to run for a further mile until the engine shuts down again. This can be repeated until the fuel suction port in the tank is uncovered and causes engine fuel starvation and loss of prime. Re-starts after run-dry shut down are not recommended. Martin
Post #321138 2nd Apr 2014 9:36pm
Page 3 of 3 <123
