![]() | Home > Off Topic > discovery 2 roof leak |
womble Member Since: 27 Jan 2012 Location: south east Posts: 272 ![]() ![]() |
morning all.a friend of mine has a 51 plate disco and it leaks water into the interior,he thinks it is the front sunroof to blame and has blown the drain tubes through with an airline.the water comes down the b pillars and out around the upper seatbelt mount also over the sunvisorand there is evidence of water in the headlining above the drivers door where it comes down to meet the door.has anyone had this problem and managed to fix it?he is considering selling the car if this cannot be sorted out.thanks in advance
I chased this problem on my wife's old DII for ages, which turned out to be two distinct issues. The first was that the front corner of the inner frame where the drain tube connects had broken off and the second was the seal, or lack of, between outer frame and the surface of the roof.
The first is a bit obscure to be honest, but the second is quite common. As a check, cover the join between the roof and frame with duct tape, which will prove that it is a sunroof problem or not. One that's established, then the solution is to strip out the headlining, remove the sunroof and re-seat it on a bed of mastic. None of it's particularly complicated, but removing the headlining is just a bit of a pain as so much has to be removed to do it. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
![]() ![]() Had the same issue on a Disco....best solution is to remove the sunroof totally, clean thoroughly all the crud in the drainage channels and bodywork/roof where it sits, inspect the drainage pipes and replace if necessary and refit using enough Sikaflex 29i marine grade sealant to refloat the Kursk. Blowing through with an airline doesn't prove the drainage pipes have not become detached or have a split in them. My headlining used to get sopping wet. I did both sunroofs, 'one off job' done twice (once on each sunroof). Easy job well worth the time and effort..... ***Great minds and all that!*** Darren obviously had same issues as me and same solution! Remove/clean/refit!*** Pipped me to the post on posting the solution.... ![]() Treat every day as if it is your last....one day you will be right!! |
thanks guys,i will pass your advice on.he was thinking of selling because wife keeps on at him and she drives it most of the time.you know how it is!!!
![]() ![]() I don't and am absolutely in no position to offer any sort of marriage guidance at all! ![]() However here's my pennethworth..... ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 ![]() ![]() ![]() |
My partners Disco 2 has exactly the same problem
![]() we had the roof lining removed, repaired the drains and all was well after reading a lot about this before the event - the common trend was that it was never the seals and always the drains - so start there first and see how you go ![]() there was a great 'how to do it' which I found when I googled 'discovery 2 sunroof leak' ![]() good luck! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
http://www.landyzone.co.uk/lz/f38/discover...99543.html
This is good Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
thanks for tour advice on this one everyone.he had it all to bits the other weekend and sorted it.i think it was the drain pipes broken.
At least that will be his SWMBO off his case and there will be no requirement to sell it on now.
