Home > Wheels & Tyres > TPMS by Comatra
TPMS by Comatra
TPMS by Comatra
4 & 6 Wheel versions
Well I brought this a while ago and time had conspired against me however I had a small window on Saturday Morning so into the workshop I went.
The Supplied kit is well packaged and clear concise instructions are included.
Having a fully equipped workshop helps but a friendly local tyre shop is good as well for the actual fitting.
Firstly remove the wheels from vehicle / trailer .
Defender process break bead on valve side .
Push tyre down by hand .
Remove old valve.
Fit new TPMS sensor tighten to no more than 7nM(use correct valve number for wheel position as per enclosed diagram) .
Reseat tyre and re balance (The new TPMS valve will affect your wheel balance).
Trailer tyres require full removal as they are 10” ones then the process is basically the same
Trailer test shots
Monitor location
4 wheel monitor on the dash Pod
Trailer as I tow for business & play I retained the Mobile option and it plugs into the cig lighter in the nominated tow vehicle Defender or Vito (even the Jump pack )
Why did I choose Comatra well it was the friendly people at the end of Phone and E-mail and the monitor options are by far the neatest I seen
What would I change well only the valve stem colour to black and perhaps a slightly thinner monitor or one that could be recessed fitted to the dash but that’s me being fussy
Post #149660 11th Jun 2012 6:16am
AJS4X4
Nice to see you getting your gloves dirty Slaphead. Thumbs Up Andy.
www.ajstyres.co.uk 01737 241370
Junction 8 M25 Surrey.
Post #150319 14th Jun 2012 2:56pm
Laughing
Post #150321 14th Jun 2012 3:28pm
TJ101
Thanks for the write up.. looking at a system myself
Nice position for the tacho Ken Whistle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #150339 14th Jun 2012 6:27pm
Nah Vito does the commercial towing Thumbs Up 3.0 V6 auto
Post #150355 14th Jun 2012 8:35pm
