Home > Maintenance & Modifications > Rear view mirror arm bracket question re monitor replacement
Brocade
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Java Black
Folks,
I am planning to replace the rear view mirror with a monitor and need to choose a bracket...the Chinese manufacturer gives me the following options: http://www.gbeshop.com/InfoBase/downloads//metal-brackets.xls
Could someone recommend which of these I should use as a replacement ?
Thanks in advance
Post #149006 7th Jun 2012 9:02am
Brocade
This is for a Puma Defender 110 by the way
Post #149008 7th Jun 2012 9:05am
K9F
It may be my stupidity but Land Rover isn't listed at all, most of the depicted appear to have four mounting holes too, so I would have to say "none of them" or just pick one and adapt it to suit. It also depends on the size, weight and mounting of the monitor you are fitting surely? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #149012 7th Jun 2012 9:32am
Brocade
Thats right, none of them say Land Rover, which is why I am asking here...
Post #149013 7th Jun 2012 9:46am
K9F
It must be me? Sigh..... Shocked
Ok then! Definately #2! Sorted! Thumbs Up Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #149018 7th Jun 2012 10:33am
