Home > Maintenance & Modifications > truckman top
mro
United Kingdom 2012 Defender 110 Puma 2.2 XS DCPU Santorini Black
truckman top
Ive just fitted a truckman top to my doublecab,ive had to remove the alluminium strip attached to the rear of cab as the top would not clear,now im left with a gap of aprox 25mm on the forward panel bottom edge of the truckman top ,what is the best way of sealing to prevent water getting in,i know i wont stop all of the leaking but id like to prevent it as much as poss
Post #147431 28th May 2012 8:11pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
it should slot into the metal " strip " at the back of cab...and have a foam seal.. Putting Dreams on Drives at JLR Solihull..
Post #147432 28th May 2012 8:16pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
Yep, I fitted mine over the strip.
I did have to trim the the metal a little for a good fit. 2002 Defender 110 DC
Post #147433 28th May 2012 8:24pm
mro
yes just had another look the strip will have to be trimmed a bit to allow the top to sit properly thanks for the replys
Post #147440 28th May 2012 8:55pm
