Home > Maintenance & Modifications > Weeping swivel seals |
ciderdrinker Member Since: 04 Apr 2010 Location: cardigan Posts: 21 |
if its only a small leak its probably not too much to worry about! changing the seals is not difficult but it is a bit of a time consuming job! Are your swivel balls pitted? sometimes this can cause them to leak, sometimes there is a little bit of excessive play in the king pin bearings which can make them leak, this can sometimes be cured by removing some of the shims at the top of the bearing
will 90 td5 csw 90 200tdi series 3 petrol series 2 diesel series 2a v8 Freelander 2 |
28th May 2012 10:15am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
What age is the vehicle? Most recent Defenders have grease not oil in the swivel housings (those that left the factory like this can be identified by the absence of a drain plug on the swivel housing; those retro-greased cannot). If the swivel is grease-filled, it shouldn't leak oil even if the seals are bad.
If yours is grease filled and is leaking oil, the most likely reason is that the oil seals at the outboard end of the axle-tube (ie inboard of the swivel housing) are leaking and allowing axle oil to migrate into the swivel housing (check the diff for oil loss). These are a bit of a pain to replace, but no more so that the swivel housing seals; to replace either the swivel housing has to be removed from the axletube. |
28th May 2012 11:31am |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
my swivel seals were changed under warranty at my first service in january - i didn't know that there was a problem.
i have now got a definate leaking nearside swivel seal which the dealer is rectifying in 2 weeks time! is this a common problem with pumas? |
28th May 2012 12:06pm |
It's a common problem with Land Rovers of all ages! Steve.
28th May 2012 12:27pm |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Hi,
It is a 2009 MY 110, with about 34K miles on the clock. About a year ago I had a seal replaced on the right rear wheel hub, I had a leak however it manifested itself on the front of the wheel. The current leak shows as two dribble/weeping trails on the inside of the wheels... |
28th May 2012 12:38pm |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 |
I have had to have the swivel housing replaced. Initially we thought it was just a seal, but after investigation and a bit of wobble in the wheel when I went over a bump,, turned out to be the swivel housing with lots of play in the king pins. Current:D4 HSE
Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
28th May 2012 9:33pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8029 |
later ones are grease, as yours will be. the hot weather is showing up weakness in the seals i would of thought. take some pcitures of the leaks and get them to replace the seals under warranty.
short term, no problems with it, if its still leaking there is still grease/oil in it! parking on the slope wont make any odds or have caused the problem. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
29th May 2012 6:16am |
Thanks for the helpful responses guys.
Sadly the warranty expired last month. I'm guessing it should be good for our trip this weekend to Normandy, and I'll sort it with the local garage when I get back. That reminds me... I'll have to do some searching and/or post a thread asking if anyone knows decent places in/around High Wycombe (as well as to update me profile since we moved from Oxfordshire). I'll go to a garage as swapping the seals looks to be beyond my basic mechanical skill. Not that I wouldn't mind having a bash, but I don't even think I've got all the tools.... plus they'd probably all roll down hill on this silly driveway. |
29th May 2012 11:19am |
Here are a few pics of the leaks, for what it is worth:
Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
29th May 2012 1:05pm |
yep outer seal has gone. wouldn't be a problem for your trip i wouldn't of thought. you can always top them up with EP90 or more grease.
easiest way to change the seal for a quick fix is do it all insitu just cut the new seal prior to fitting to get it around the axle and then put the cut section at the top. 30mins longer was - just remove caliper, undo the 7(?) bolts holding the whole wheel station onto the axle, remove wheel station with shaft still attached. place on bench and remove metal seal guard, then seal, then replace all. an hour or 90mins even longer way - go on the from the outside edge and remove hub etc etc. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
29th May 2012 2:00pm |
I've seen a lot worse than that, if I were you I'd clean them off [bit of degreaser and gently wash away and keep an eye on them, it only takes a little bit of semi fluid grease / ep90 to make a lot of mess. Steve.
29th May 2012 7:58pm |
Thanks guys. I'll get out there and wipe it down, keep an eye on it.
29th May 2012 8:15pm |
Hi all,
About 2 weeks ago I wiped the dribbling oil and I've not seen any real return yet. Perhaps there is none left to leak out |
16th Jun 2012 8:00pm |
