![]() | Home > My Defender > My lovely ''new'' CSK rims, Roll Cage and others |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
Yes there are M&M. After almost 4 years I can say that there are good, although sun of Greece beat the colour ![]() They are now faded. www.newfoundland.gr |
Today it arrives the 102mm silicone hose so I try to do what Alex did.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Didn't finish yet but I made a test and there is a deference, real deference!!! Thanks Alex for the idea ![]() And as I get bored with plastic ending caps I replace them with stainless ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge www.newfoundland.gr |
I finally finish the hose
![]() Click image to enlarge ![]() Click image to enlarge I installed working light ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I find a small hole and i pass cables ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I also installed front parking radar ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Last I made and safari instalation ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge www.newfoundland.gr |
Nice to read that you finally fitted it !!
I am sure Nino (tuff.gr) will make one for you(it was his idea ), he is master of customs ![]() Just ask him !! www.newfoundland.gr |
i finally installed CC.
i took it from Mobile Center. easy installation, took me less than 2 hours. first connection with brake pedal ...... ![]() Click image to enlarge ![]() Click image to enlarge then, connection with console speedo ![]() Click image to enlarge third connection was with clutch cables. i pass purple cable from water tube of washer jet ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge then conection with speed pedal. you need help at this point..... someone helped me...... ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge last connection was with ingition cable......i used cable from wiper switch ![]() Click image to enlarge then plug all looms to main unit and finished...... ![]() ![]() Click image to enlarge i enjoyed it this morning going to work. thanks Tim ![]() |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 ![]() ![]() ![]() |
![]() ![]() I am not jealous....yet... ![]() ![]() |
finally
![]() ![]() Click image to enlarge ![]() Click image to enlarge when i start restoration i will put photos if it is allowed...... www.newfoundland.gr |
It appeared a new genuine roof rack with no clamps with a really special price so i couldn't resist ........
As i have a roll cage i had to make some mods. i had to make my own clamps as mama LR wants a fortune for them. I already had 2 pairs of safari 3000 and a badge of a SERIES 1 ![]() So, i resided to play the game. Bad or good, i don't know..... here the result ![]() https://www.facebook.com/profile.php?id=67...tif_t=like www.newfoundland.gr |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 ![]() ![]() ![]() |
Hi Pouf,
How long was the 102mm pipe you used? Is 1metre long enough? Tom @tditomprice 100” Defender Hybrid 2010 Alaska White 90 HT |
Yes it is enough.
You can find one on eBay. www.newfoundland.gr |
I made a trip to Germany last May, so before our trip it was time for some small fixings... after 7 years my lady had enough surface rust although she lives in Athens...
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge www.newfoundland.gr |
After a very good wash i started with rust convertor. I used Rostisol.
...and finished with buzzweld.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge www.newfoundland.gr |
Finally i made crossmember
