Home > Td5 > 1999 td5 engine
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
1999 td5 engine
Does this model engine ecu need a remap or chip ??
Regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #143461 4th May 2012 9:57pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
I think you can do either , I have a td5 1999 and it has a later nnn type ecu that is remapped. Thumbs Up
Post #143462 4th May 2012 10:02pm
big steve
Hmm I thought they were different to later ecus who map have you pt I had a twisted box in my old defender 2015 2.2 tdci hardtop xs
Post #143464 4th May 2012 10:09pm
amondeggs
I wish I knew, it was done before I bought the car and I never asked the question. Goes really well tho considering it's done 200k miles. Still have old ecu msb type makes massive difference when I put it on just to try. It did not stay on for long lol.
I personally like the look of the attic boxes where you can switch between 3 different maps. Thumbs Up
Post #143468 4th May 2012 11:30pm
big steve
Yer I have the bas interface for my puma but was unsure about it working on early td5s
Cheers steve 2015 2.2 tdci hardtop xs
Post #143477 5th May 2012 7:23am
Early Td5's, like yours at 1999, should have had the non-flashable ECU's (and usually 10P engines), although like you say, yours has the ,ater NNN ECU which can be swapped in place of the non flash type (i think that the early ECU is no longer available anyway thesedays.)
Again, i think, that the 15P engine and flashable ECU came in about 2002 when the dash was upgraded slightly with the center switch panel.
Post #143526 5th May 2012 7:58pm
big steve
so what can u actually get from a td5 reliably 2015 2.2 tdci hardtop xs
Post #143618 6th May 2012 4:50pm
Mine's running 195BHP, from IRB, with a VGT turbo.
Pulls exceptionally well, doesn't smoke too much (passes the MoT anyway), and the temp guage never seems to move up when gunning it up steep hills.
Post #143637 6th May 2012 6:29pm
jst
as Jamie said, 99 Td5 is non flashable if std ECU.
stick to less than 200bhp for reliability. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #143669 6th May 2012 8:35pm
big steve
I shall probly go to Bas or alive !?!? 2015 2.2 tdci hardtop xs
Post #143678 6th May 2012 9:14pm
big steve
Also on this truck the mid section has been replaced but I can't see an cat on the truck did they come with one or has it already bean removed
Stvrb 2015 2.2 tdci hardtop xs
Post #143702 6th May 2012 10:26pm
landy andy
I think yours is too early for a cat.
Post #143718 7th May 2012 6:28am
bell-auto-services
Pop over with it one day Steve and ill add a chip to the ecu if its a old MSB type. As said by jst,stick to less than 200bhp for reliability.
Pete
Post #143748 7th May 2012 9:38am
big steve
No probs pete I'll send it down just put the highest performing map you do onto it
Cheers mate
Steve 2015 2.2 tdci hardtop xs
Post #143753 7th May 2012 9:54am
T1G UP
get another turbo manifold and get it skimmed steve. that'll be the first thing to play up. Guess you have removed the EGR, the cat..if its got one and the mid box.
Is it manual?
Post #143755 7th May 2012 10:11am
