Home > Expedition & Overland > What do you use your Inverter for ?
I've just come by a 1200watt 'Industrial' 12v to 240v inverter and wondered what it was that people ran off their inverters .... ?
Post #143014 2nd May 2012 3:14pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
The wife's hair straighteners?
Post #143017 2nd May 2012 3:16pm
SGH
Hair Dryer...
 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #143037 2nd May 2012 4:58pm
AndrewS
I have a 1500w and run 110v transformer, plasma cutter, loads of other stuff. 130's have feeling's as well you know Smile
Post #143065 2nd May 2012 7:25pm
Whistle
Post #143066 2nd May 2012 7:26pm
landy andy
As above wife's hair drier/straighteners, camera charger, and battery charger for battery drill driver
Andy
Post #143082 2nd May 2012 8:13pm
landy andy
Double post
Post #143084 2nd May 2012 8:13pm
noworries4x4
I have a 800watt inverter bolted to the baulkhead behind the passengers seat heavy duty leads straight down into the battery box, as for what it does, 3x 2way site radio chargers, 2x Remote contol battery chargers, 1 Makita li-ion charger all permantly plugged in to a 6 way extension 1 plug left for either lap top or phone chargers. If we are working on a very remote site with no facilitys i have a hotel style 750watt kettle boils a litre of water in just under 10mins (coffee adict) sachets of 3in1 coffee always carried (and tea bags for mrs noworries)
Picture while the new vehicle was being set up (wiring all in spiral wrap and cliped properly now) If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #143089 2nd May 2012 8:41pm
JWL
Mine doesn't run a hairdryer, not enough hair Shocked , the hair straighteners are defunct in my house or truck, the wife went walkabout 18 months ago Cool What it does do is recharge batteries for the Makita and Paslode, does the recharging of the laptop when out and about, the boys PSP, haven't got round to getting a 12v charger lead for that yet. I also have a tubular greenhouse heater attached to the legs on the 2nd row seats, I plug that into a lead from the garage overnight when it's cold and into the inverter when on the move untill there is sufficient heat output from the trucks heater Whistle I also use it to plug the airbed pump into when camping. It will run a 4 1/2" grinder, a 150w flood light, there is a block of stables I occasionally visit and it's easier to run the 4 striplights off the inverter than struggle to hear yourself think running the womans generator Rolling Eyes Once you get one, you'll allways find new uses, whether they are actually usefull or not Whistle
Post #143096 2nd May 2012 9:08pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Let me give me thoughts on these. (I graduated in electronics and did my practical end test with a project inverter and solar power and was involved in building them in my first job. So i have a long time interest in inverters)
We also had long thoughts about one, 1200W seems to be the standard now. and a true sine for 300 something is a possibility from the financial side.
Even if i was already sitting in the car ready to rush off purchasing one i all of a sudden saw the light and went sorting all electronics we carry to see if the 1200 watts were sufficient.
3/4 of what you are carrying can be used on something in the range of 5 to 19vdc, check the power supplies. So basically you are downstepping the 220 anyway. Buy a good DC-DC converter and the right plugs and you cover a lot already before you start wasting amps on upstepping to 220 and then downstepping to some lower DC voltage. Both steps waste energy, simple.
Anything not true sine-wave can cause issues and is to me not worth its money as it causes even more waste by making the device it is connected to even less efficient. (so not only internal losses but also secondary losses)
We have a 150w can sized one which is doing everything i need, being charging those things that cant be put on 12vdc or which we don't want to risk (notebooks, video and photo equipment, power tools)
Another issue with inverters is that running full power will eat your battery in minutes, not hours if the engine is not running. (mainly as voltage drop will make it go into protection before the battery can recover)
And using a 1200W inverter with a typical 80% efficiency to run a 35w charging device is nuts in my logic.(you consume more amps in losses than your charger is using) The 150w will run longer and more efficient.
Power tools are available in battery versions which will run longer and better than 220 ones on an inverter
Using half of the battery to cook 1 liter of water while a couple of minutes more and the coleman does the same leaving my amps available for the fridge... etc etc
I saw a lot of people once they have their inverter build a collection of 220v appliances which can be easily and without sacrificing comfort be replaced by 12vdc versions. (even saw a guy running normal 220 bulbs as campsite lights..... Shocked )
If i could have one for free or near that i would have it and install it, just because i can. But a real purpose for these big power versions i did not find yet.
I am sure for some people it makes sense, eg ambulances etc where there is no option to run their instruments on 12vdc.
Just 2 cents
Smile
Post #143620 6th May 2012 4:58pm
Our key cutting vans run pure sine inverters at about £1800 each and we run them off two parallel truck batterys
Post #143628 6th May 2012 5:32pm
It's a lovely bit of kit this inverter, was used by a windscreen fitting company to run a hot air gun, but as has been very well pointed out, most stuff can be run off 12v ..... Might sell it on I think
Post #143692 6th May 2012 9:41pm
JWL
I know that when charging some of my power tools is defying logic, i.e. the Paslode is IIRC about a 5v battery(well less than 12v) and there is an adapter to run the charging holder with a 12v lead. What happens when trying to charge 14,4v or 18v batterys?
Post #143700 6th May 2012 10:16pm
The Musketeer
United Kingdom 1988 Defender 90 Other HT Cairns Blue
Can anyone recommend a good converter to run x2 240v sockets, looking at powering a laptop and a spare for whatever else.
Not looking to spend a fortune but would like something permanent as opposed to the cig plug jobbies!
S Good things come to the wild and free
Post #143856 7th May 2012 7:04pm
JWL
All mine have come from Maplins, not used the ciggarette sockets, just hardwired in with a fuse.
Post #143891 7th May 2012 8:47pm
