Home > Td5 > Brake lights |
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 |
Back up to a shop window at night and apply the footbrake to check for sure.
16th Apr 2012 10:41pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17387 |
Faulty earth connection on n/s brake/tail light unit.
16th Apr 2012 11:08pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Agreed. |
16th Apr 2012 11:15pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Start with a new bulb, simple stuff first
Andy |
17th Apr 2012 6:39am |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
So then, was out with a friend today so got out and had a look myself.
1. Brake lights function perfectly when the side lights or low beam lights are OFF 2. When the side lights or low beam lights are ON and the brake is depressed: The rear right light functions correctly lighting up brighter than when no braking However the left light dims significantly to the point where it is almost entirely extinguished. I will order some bulbs first thing tomorrow. Recommendations? May as well get brighter ones if possible whilst I'm at it as they are pretty poor Will Defender 90 XS TD5 (03 Reg) |
17th Apr 2012 3:43pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
It won't be a bulb - it will be an earth problem. Might even just need the contacts cleaning. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
17th Apr 2012 5:01pm |
Like I said, faulty earth connection on n/s brake/tail light unit. Entirely normal behaviour if the earth has failed, since most of the time the brake and tail-light bulbs are now earthing through each other in series. With both lights energised (ie tail lights on and brake pedal pressed) there is no path to earth and hence no light output. Fix the faulty earth and the problem will be solved. It is very unlikely that changing a bulb will make any difference except to the amount of change in your pocket! By the way, remember that the law limits you to 5W in the tail lights and 21W in the brake lights (though probably no-one will notice if you go up to a 10/21W bulb). |
17th Apr 2012 5:21pm |
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 |
yep sounds like a bad earth to me
17th Apr 2012 8:26pm |
Okey dokey chaps I will find the earth and have a look as soon as the weather brightens up.
Thanks a lot Will Defender 90 XS TD5 (03 Reg) |
18th Apr 2012 5:40pm |
i've done a bit of research before attacking this.
Is the earth point i'm going to be after adjacent to the rear screen wiper motor? I could be wrong but on looking around that is the only bit of info i could find on it's location Will Defender 90 XS TD5 (03 Reg) |
20th Apr 2012 8:32am |
Waldo,
To creat the symptoms you have described the earth side of the two bulbs will be connected together, but won't be connected to earth on the vehicle. I don't have a Td5 electrical manual, but on the Puma, daft though it sounds, the earth point for all the rear lamps is in the vicinity of the transfer box:- Click image to enlarge Connector C0558 is the earth for the NS tail lamp and reversing lamp, connector C1412 is the earth for the NS brake lamp. This is the area I would check first, assuming of course that the Td5 has a similar arrangement (which is highly likely). |
20th Apr 2012 10:28am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Got an usual one here - at least I think so?
Rear n/s works fine on side light but not on braking. Took bulb out but it looked fine so I went for fuses but they were all ok. Had another look at the bulb and although the glass was a little black the filaments both looked fine and no evidence of corrosion? Not know bulbs to fail without evidence of filaments failing? |
11th Feb 2015 8:42pm |
If the glass is black it's likely to be a bulb failure
11th Feb 2015 8:45pm |
quite often bulbs look good but are no good , if you not got a spare bulb swap it with the other side and see what happens then your know if forsure its just a bulb needed |
11th Feb 2015 8:53pm |
