Home > Expedition & Overland > Just a hello from morocco
Page 2 of 2 <12
shazzy90
diesel was from a arfriqe garage ,and was not only my 110 that had problems,two other td5s devoloped noisy pumps,which went back to normal after a couple of hours driving and a puma 2.4 tdci which ran rough for 20 seconds at a time ,then cut out,after 6-7 times of this it slowly came back to life,but sadly mine did not,so i replaced the pump,on opening the damaged pump from the outer casing,waxing was evident around the bottom of the pump,it may have been less than -2 and with a wind this would have been even less ,i hope this explains a bit better
Post #140180 18th Apr 2012 7:50pm
Page 2 of 2 <12
