![]() | Home > Maintenance & Modifications > Swing away Wheel Carrier |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Got some nice pics from an Auzzie bloke (thanks Murray) and tried to make my own to save some money.
It's not yet complete but one more day and I should be there. Not the best of jobs by a long ways but let's see if it holds up on the bumps (especially the welding.) ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Puma 110 - gone Series III 1973 - going strong |
Look this
![]() Nakanenga dot DE |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2461 ![]() ![]() ![]() |
The main weight on all these devices are attached just to the frame. Is there any problem on the Mantec (or so) type of wheel carrier attached to chassis and body? Puma 110" SW
The less weight on the body the better.
However, compared with the standard mount, the Mantec one does a great job of taking the weight onto the crossmember and removing potential for damage. In fact, i think it's holding my rear door in place as well ![]() These home-spun ones look the business. They look pretty heavy, though. dgardel - that's some pretty nifty fabrication. I love the crossmember shaped bracket at the bottom. I guess if you have the skill, time and patience then it is satisfying to build your own. For the rest of us, the Mantec does a good job. ![]() + New Defender 110 First Edition |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Just wait till you see the one Sonic has made.......im drooling and ive only seen the prototype
