![]() | Home > Puma (Tdci) > EGR blanking |
Bear in mind that some of the negative effects on performance from an EGR valve will only build over time. There probably won't be much 'before' and 'after' difference on a relatively new vehicle. Darren
Brian The thermocouple on the EGR side with EGR closed is in a position w/o mass flow, I think it is not a significative position... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
I did a write up here ![]() http://www.defender2.net/forum/topic10564.html?highlight=oem+fuel |
DG, I don't think the position within the manifold would make that much of a difference in received temps as the expanding gas will reach all areas of the manifold due to the back pressure of a laboured engine in accelerating. The ideal position above would give a true EGT of the upstream gases entering the turbo but I am thinking that the thermocouple would be more likely to fail there rather than at the EGR cooler manifold? This was a scenario I was thinking of doing but the EGR closed by remap is a much easier option than removing everything. I will be looking at getting a ceramic coated manifold with the thermocouple fitting at the turbo flange at a later date, whether I get it made specially or if one of the tuners add it to their stocklist, as Alive does just now for the TD5. I would be very interested if anyone has fitted a EGT thermocouple upstream of the turbo and where and how they fitted it, ideally some one with both upstream and downstream couplings would be great just to get feedback on the differences in temp between them. I was going to get the relevant nut size for the coupling then drill the manifold and weld the nut onto the manifold rather than just drilling and tapping the manifold direct? ![]() Brian. |
Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58 ![]() ![]() ![]() |
Lorryman, thanks for your clear explanation on subject ![]() Cheers Puma 110 |
Hi Denis, I don't know of anyone else who is going down the same route as Entreq with their EGR killer kit. The problem that you overcame with the MIL lamp seems to be the biggest hurdle to conquer without having to add a software fix, and I know now this cannot be done without the MIL light lit permanently. I have the EGR closed by software and have had zero issues with the EGR, this for me is the best option and the cheapest way I have found of doing it. But your way of totally blocking the gases yet having the EGR valve work as it should is brilliant.
Brian I made a lot of engine experiments and investigation and the right position for the thermocouples is where the flow speed is a maximum. The position on the EGR side is a sort of stagnation zone for the exhaust gasses (also if your egr is working because 1.the mass flow is lower than the real exhaust gas flow 2.EGR is always closed on WOT and max power engine request) In this case you can read 200 - 250 °C less than the real one. see here http://landrover.megacloudstorage.com/item...7baa616faf. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Cheers DG.
I have scrapped the full removal of the EGR and won't be fitting an EGT there now as the cooler is still present. I have been looking into getting a manifold altered and getting a ceramic coating on in preparation for the stage 4 remap from Alive once I'm out of warranty in a couple of months. Now all I need to do is decide which EGT system I'm going to fit ![]() |
My selfmade manifold ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
