Home > Puma (Tdci) > TDCI wiring diagram |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 153 |
Not yet bin a bit busy I need to knuckle down to it soon though Phil |
23rd May 2012 9:34pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Has anybody got a copy of the 12MY on circuit diagrams ?
All of DG's links don't seem to work anymore Cheers Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
24th Mar 2013 5:42pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Are you using DG's latest links. Just checked them and they are working fine.
http://sdrv.ms/X3rx3k LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
24th Mar 2013 7:03pm |
Must have missed that link. Thank you - all sorted Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
24th Mar 2013 7:10pm |
Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
24th Mar 2013 7:15pm |
110 John Member Since: 11 Jan 2014 Location: Northumberland Posts: 158 |
Great stuff cheers
8th Feb 2014 5:46pm |
Hi John,
Welcome to the forum. Thread revival.....Good to see you located the information you needed yourself. Well done! Dgardel has a good set up there with just about everything the enthusiast may need to get themselves sorted. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
8th Feb 2014 8:23pm |
Thanks yep want to wire a battery back up siren on the existing factory alarm the AS10 tried fitting a Sigma S30 but conflicted with the factory one so removed the sigma
8th Feb 2014 8:54pm |
pcman Member Since: 04 Feb 2014 Location: Bangkok Posts: 2 |
Thank you
13th Feb 2014 10:33am |
Still trying to get my dash to work think I am going to try and rework a defender td5 one I think
15th Feb 2014 9:10pm |
http://1drv.ms/MpIZgd for td5 and the other old ladies Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
16th Feb 2014 5:33pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
@ Landyman
I've just nipped over from the Disco3 forum, my son and I are considering fitting a puma Bulkhead and dash into a 2000 td5 with a rotted bulkhead, partly for the more modern look and partly for the improved heater as well as needing a bulkhead repair/replacement anyway. How did you get on with yours? I know there are some differences around the bell housing tunnel and I've heard there is a problem with the heater box getting in the way of the gear stick. Looking at issues with the instruments, we may end up going down the same route as you've suggested with grafting in the original td5 bits. |
21st Mar 2014 8:53pm |
also the gearbox lever "inside" the puma facia...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
21st Mar 2014 9:10pm |
Clive sorry for the late reply we ended up using a r380 out of a discovery two. Then we managed to get the gear levers next to each other as the high low range lever is cable driven custom made a transmission tunnel had to cut into the seat box to get the levers to work. This weekend hopefully get the td5 gauges into a custom dash pannel. Phil |
28th Mar 2014 8:51pm |
