Home > Td5 > Serpentine belt adjustment.... |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1115 |
How does the serpentine belt adjust?
Mine is squealing loudly when the aircon is working. Its not long since been replaced by the previous owner, so I want to check the tension. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
27th Mar 2012 1:54pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5788 |
You can "force" the tensioner into the belt, and this keeps tighter than just releasing the adjuster. Trick I learnt from land over tech
Andy |
27th Mar 2012 7:25pm |
Ok, I will have a look at that method. Its calmed down a bit now. 2021 Defender 110 X-Dynamic HSE D300 MHEV
27th Mar 2012 9:40pm |
changill Member Since: 13 Dec 2008 Location: North West - Preston/Lancaster Posts: 27 |
Might you need a new tensioner? Only Alcohol Can Save me Now
Nanocom Available in the North West |
2nd Apr 2012 7:52pm |
