Home > Maintenance & Modifications > Horns! |
The Musketeer Member Since: 07 Feb 2012 Location: United Kingdom Posts: 193 |
My horn (on the truck) is pretty, well, Fiat 500 like has anyone fitted this from Bolt on Bits? http://www.ebay.co.uk/itm/12v-Klaxon-Old-V...930wt_1037
I fancy an awooga horn. Is it loud and where does it fit, it doesnt look like it would get behind the grille? Good things come to the wild and free |
20th Mar 2012 8:25pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Where exactly is the horn located? Mine is beyond pathetic, either its or was always kack. Think it needs a half decent 2 tone like you'd find on any modern car for about a tenner.
Looked through Rave but there's no mention of the horn and how to find it. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
20th Mar 2012 8:35pm |
Wouldn't you know it, just found out its behind the LH headlamp. Doh! 2016 D4 HSE
20th Mar 2012 8:37pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 |
Your horns are located behind the headlamps on Td5 onwards.
20th Mar 2012 8:40pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
It could just be me but I've got a feeling there's two one each side. Noticed when I changed headlights. But I could be wrong might have just noticed an empty hole. Wasn't paying much attention to horns. |
20th Mar 2012 8:41pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
yes one each side, well they are on a 2007 Mark |
20th Mar 2012 8:44pm |
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1096 |
I'd go with these: Ring twin air horn
The horns are essentially the same as 2 tone emergency 'dee daa' but it's only a single output compressor so you get a PWAARP. Remember that your alarm sounds the horn, so if you have a habit of accidentally setting your alarm off when leaving for work early, your neighbours may well begin to dislike you |
20th Mar 2012 8:46pm |
I thought so. Damn awkward to get to I think though. Wonder if it's only Puma's that have the two horns? Mine seems perfectly good no worse or better than to be expected. |
20th Mar 2012 8:47pm |
Where would you mount those? |
20th Mar 2012 8:48pm |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
I got a set of these on the 90, pretty decent sound and mounted nicely behind the grill, been on 3-4 yrs I guess with no problems. Recommended Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
20th Mar 2012 10:20pm |
That's good to know. Are they louder that standard though? |
20th Mar 2012 10:29pm |
twin horns on my 110...loud enough
20th Mar 2012 11:07pm |
They are a damn site louder than the old one was, no louder that the new 110 one but a bit 'harsher' maybe, I'll posts a pic when I get time DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
20th Mar 2012 11:21pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
I have one ahooga horn fixed on the left wing . I made a wiring for the horn with one relay and a Button/Switch on the dashboard . Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
21st Mar 2012 12:12am |
