Home > Puma (Tdci) > Picking defender up
luke11
2008 Defender 110 Puma 2.4 XS DCPU Tonga Green
Picking defender up
Quick question. Are the standard rear towing eyes strong enough to pick up the back of a 110 doublecab with a telehandler so i can pressure wash and waxoyl underneath easily? And if not is there anything else i can attach the straps to easily
Luke
Post #132684 19th Mar 2012 9:23pm
Green Machine
NO!! This sounds like a pretty good way to seriously injure yourself, or worse. The 'towing eyes' to which you refer are simply lashing-down eyes for securing the vehicle on a transporter or similar. They are not suitable for anything else.
You've inadvertently stepped on a real hornets nest here! There have been many hours of debate about these lashing-down points, particularly with regard to recovery. Basically, they're just not strong enough for anything that involves any force or load.
I'd suggest that some good trolley / bottle jacks and decent axle stands are the only way forward with this one. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #132692 19th Mar 2012 9:48pm
landy andy
Do you have tow ball?
Andy
Post #132702 19th Mar 2012 10:03pm
luke11
Yeah I do, Dixon bate adjustable type
Post #132703 19th Mar 2012 10:05pm
landy andy
I am sure that not all would be happy with, but I would use a strop through that on to the telehandler.
But would recommend big set of stands, or even an oil barrel under each rear wheel before you get under it.
Andy
Post #132705 19th Mar 2012 10:12pm
martin010161
Hi,
I have worked in motor trade 35 plus years and seen some bad things from cutting corners. For your own safety use axle stands or a ramp. not worth the risk.
Post #133459 22nd Mar 2012 5:34pm
Zagato
Shocked Use axles stands or similar my friend if you have to & chock the wheels Shocked
You can get under the vehicle to put your rust prevention on without raising it! Watch Waxoyl on your plastics, rubbers e.g. door seals etc it can ripple/damage stuff! Much more effective and easier products to use out there than Waxoyl.
Post #133460 22nd Mar 2012 5:44pm
Retroanaconda
Forklifts/telehandlers are very useful for changing axles, I've done it many times on mine:
Very good for this purpose as you can tweak the vehicle height in order to line up the suspension easier. But I'd never get under there with it like that! It's not worth getting flattened to save a few hours work.
For your planned job you'll need to be under there so don't bother with it. You could put it up on some decent sized wheel ramps, that will give you a lot of space to move about under there.
Post #133468 22nd Mar 2012 6:30pm
The other issue is even if you don't get under there (very dangerous) is if anything did happen what about the damage that would be done Exclamation 3000kg there not something to mess with. Idea
Post #133525 22nd Mar 2012 8:41pm
Whilst you're not wrong in principle, the back end of a Land Rover weighs nowhere near 3000kgs. The whole vehicle is only around 2 tonnes and the back end will be less than half that. Darren
Post #133538 22nd Mar 2012 8:57pm
Only giving rough over estimate. Even 1000kg would be enough either way. Off topic but am I not correct in thinking that a 110 weight is roughly 3000kg give or take? Total vehicle weight of course. Maybe I'm thinking something different. Thumbs Up
Post #133540 22nd Mar 2012 9:01pm
The 3000kg figure is fully laden but I'd hope nobody would attempt to lift or jack one up with a tonne of something in the back. Empty, they're around 2000kgs - slightly less for a 90, of course. Darren
Post #133553 22nd Mar 2012 9:25pm
T1G UP
110s are 2050kg or there abouts...same as my old D2 5 seater. 90 TC are about 1600kg
Post #133555 22nd Mar 2012 9:26pm
Thank you TiG Thumbs Up I must have been thinking something else completely different. Again Laughing
Post #133558 22nd Mar 2012 9:29pm
