Home > Technical > Method to clean injectors (approved by LR) SSM40324
Eduardo
Models
LD - Defender
LJ - Discovery Series I
LP - Range Rover
LM - New Range Rover
LN - Freelander
LT - Discovery Series II
LA - Discovery 3
LS - Range Rover Sport
LF - Freelander 2
Title Petrol fuel injector cleaning equipment
Last Modified 30-JAN-2009 12:41
Category Engine
Symptom 404000 Fuel System Concerns
Content Issue: Fuel injectors clogged leading to potential problems such as poor running, poor fuel economy, excessive exhaust emissions, hard starting, rough idle, misfires and engine detonation.
Cause: Poor fuel quality or fuel contaminants restricting the fuel injector flow rate.
Action: Land Rover engineering now approve the use of the ASNU ultrasonic fuel injector cleaning system on Land Rover fuel injected petrol engines.
If the equipment is purchased, training and operating instructions for using the system will be supplied by the ASNU representative.
For fuel injector remove and refit procedure refer to Global Technical Reference (GTR) section 303-04.
Contact details for ASNU and descriptions of the ultrasonic cleaning systems available can be found on the ASNU website (www.asnu.com) Eduardo
Post #9882 18th Apr 2009 2:19am
Martin
Site Admin
This is only for EFi petrol engined Defenders - so the 50th Anniversary V8 Smile
Post #9886 18th Apr 2009 1:00pm
Eduardo
You are right Eduardo
Post #9891 18th Apr 2009 6:39pm
Bullet
South Africa 2003 Defender 110 Td5 DCPU Rimini Red
What about the diesel models? Question
Post #10057 22nd Apr 2009 6:57am
