Home > Wheels & Tyres > Rear Panel Damage Caused By Spare Wheel |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Sorry to hear that Mike
It's a poor design if you look at SW Defenders I should think 99% of them have a dented rear panel from the tyre hitting the panel when the door is opened too far. A gas strut is the answer form Overland 4x4 (think it's a Nakatanenga one! See site sponsors) |
13th Mar 2012 7:08am |
Mike - also consider fitting a spare wheel carrier, this takes the load of the wheel off the door and door hinges, especially if you are fitting bigger tyres.
I have mantec which is strong and reasonably priced Last edited by bpman on 14th Mar 2012 1:02pm. Edited 1 time in total |
13th Mar 2012 7:32am |
We run 255/85/16 (which are slightly larger then 235/85) on our 110's and have not experience trouble with them hitting the rear panel.
We do have swing away wheel carriers fitted however. If the rear door has opened with some speed/force then with flex etc the door may have opened further then normal. Cracked paint is the first priority. Larger tyres put more strain on the rear door then the standard ones so a swing away wheel carrier may be beneficial. Combined with a gasstut they do make openingthedoor easier,more stable with door open, but more pressure is required to close the door. Brendan |
13th Mar 2012 8:07am |
This is a common issue and one that Land Rover should have sorted long ago in my opinion. You can also wind the spare wheel studs out/fit spacers. Mine was sorted when I changed my wheels and the different offset took the wheel further out.
A swing away wheel carrier is of course the another solution but comes at a cost if that's what you want! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 2nd Oct 2014 7:59am. Edited 1 time in total |
13th Mar 2012 8:28am |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
Except swing-away type wheel carriers are no good for SWs where you have occupants in the rear - unless you want them trapped in!
I've ended up fitting wheel carriers to my last two Defenders, because the weight of the wheel tore the door structure to pieces. I'm hoping the new (>MY02) type is a lot stronger.... |
13th Mar 2012 8:44am |
Good point and one I hadn't considered. Quite a safety issue if you carry passengers..... Knew there was a reason I didn't rush out and buy one! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Mar 2012 8:48am |
Brendan on Pumas the door is able to open too far if on a slope say or if you left it swing around after openiong it too quickly. The gas strut sorts the problem.
A rear swing-away wheel carrier apart from the cost and drilling holes into the bodywork which you really don't want to do if you can avoid it (some are attached to the rear crossmember though ) are a real hefty weight to add to your motor. Apparently the carrier is only needed if you off-road as the jolting causes the possible problem. I wonder how speed bumps and Surrey pot holed road will effect mine They now have three hinges on the back instead of just two from Series days but this was to account for the later heavier wheels. The problem is in the weakness of the ally around the hinge BUT don't Pumas have steel rear doors now? Would make it stronger!? |
13th Mar 2012 8:56am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Depends which type you fit - most fix to the door and crossmember / tub and swing with the door so no problem with passengers. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
13th Mar 2012 11:10am |
That's the sort I've fitted before. They're not 'swing-away' wheel carriers though - swing-away ones are the type that move separately to the back door
13th Mar 2012 12:12pm |
4wheeler Member Since: 13 Apr 2010 Location: Melbourne Posts: 87 |
Not good Mike.
My rear panel got a dent in it when the wind caught the door and it opened too far. Was not a happy chap. I have been able to "pop" the panel out a bit so not too noticable apart from the fact that I know it is there. It drives me nuts every time I see it. The aluminium has been stretched. The more you stuff around with it the worse it gets. I have found even new Defenders on the car lots with this type of damage. When I purchase my next one I will specify that if the damage is there, I won't accept the car. It just should not be able to happen. I would think to replace the panel and get the spot welds right would be expensive. |
14th Mar 2012 9:48am |
Yes, I have the Mantec one and the lower part is fixed to the rear crossmember. great piece of kit, I'm happy with it (my rear door also) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th Mar 2012 12:58pm |
