Home > Maintenance & Modifications > Headlight bulbs |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
Bang on Also knowing there is a higher output does mean a slightly shorter life span. But the improvement is so good it's worth it! |
8th Mar 2012 3:09pm |
I found the cheapest place for Crystal's was Paddocks |
8th Mar 2012 3:10pm |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
Phillips in my volvo lasted a year, thats 14,000 miles with the lights allways on.
Cheepo bulbs from local spares shop last about 3 months, and with the amout of skin I loose fitting them the scars have only just healed in that period of time. |
8th Mar 2012 3:45pm |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 |
I have a half way through pic in my gallery for the Halfords ultra bright 120% bulbs. The standard bulb is a cheapo unbranded bulb ===================================
Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
8th Mar 2012 5:08pm |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
Update
New bulbs are a million times better. The "main spread" area is lit in a nice sharp pool of very bright white light and where the light spreads beyond that with less intensity you can still see very well. Still adjusted the headlight angles for perfection but still incredibly happy!! Thanks guys Afraid I don't have before and after pictures as I really needed them fitted Will Defender 90 XS TD5 (03 Reg) |
14th Mar 2012 11:28pm |
What did you get all together then in the end? |
15th Mar 2012 11:14am |
Slamed some philips extreme vision +100% bulbs in, that's it!!!
15th Mar 2012 4:00pm |
