![]() | Home > Africa > Puma performance in Africa |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 588 ![]() ![]() ![]() |
Hello,
We are just in the process of organising a holiday Starting in Livingstone and finishing in Windhoek. The company is 'safari drive' and they use 2.4 Puma engine 110's Maybe contact them to see if they have had any problems? from talking to them I believe they are happy. I think if I was unsure of the fuel I would filter it before filling up with a 'mr funnel' to be sure the fuel is clean. Steve ![]() |
dkwillo Member Since: 04 Mar 2012 Location: Zambia Posts: 9 ![]() ![]() ![]() |
Cheers Steve
Will look them up. Where do you buy a "Mr Funnel"? Cheers |
Hi,
I got mine from here http://www.midlandchandlers.co.uk/ but I guess they are readily available. Great bit of kit. Steve ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
The most important thing would be to give it a thorough check over and test drive before you drive it away for good and ask yourself if you have problems how practical is it going to be to fix them.
You just have to keep in mind it's not an old TDi and if anything does go wrong somebody with experience in vehicle electronics may need to be at hand. I love my TDCi but I not sure I would have the courage to own one if I was away from a Dealership, a TDi on the other hand is so simple for self maintenance and will swallow any old fuel ![]() ![]() |
Thanks Zagato
All valid points! At the moment I keep swinging between upgrading from my 300 Tdi to Tdci for long road trips or spending some money and upgrading what I have! Cheers |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2663 ![]() ![]() ![]() |
Keep the 300Tdi, it'll be easier to fix in the bundus ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4748 ![]() ![]() |
Check out the Australian site as they have no bother going to remote areas with their Pumas.
http://www.aulro.com/ The tdi is a good vehicle. I drove a 200 tdi 110 for 16 years but have a Puma now. The Puma is more comfortable, quieter and user friendly than the 200 tdi but whether that makes any difference on poor ground with low range work in the back of beyond is debatable. Never had any bother electrics wise with the Puma. If your tdi is good you just need to size up what benefits a Puma will have for you. Both are very good vehicles. In Land Rover's Working in the Wild (Manual for Africa) booklet, it sets out how to run and maintain your Land Rover in the wild. From setting up servicing areas to driving. It does state that the Td5 (this was the current model when I bought the book) is a complex vehicle and states regarding the electronics"very little can be done by way of field maintenance without powerful computers and the relevant programmes." Also if the ECU goes "down" by being introduced to water, the "get you home feature" could also fail. I suppose the same could be said for the Puma, but the Puma ECU is fairly well protected from water as it is high up on the bulk head. Like others have said just talk to owners in your neck of the woods. Get in plenty of basic spares if you do go for a Puma. Get them with the vehicle and you might get a good deal on them. Also there are basic diagnostic tools on the market that you could invest in but you can never cover ever eventuality. Good luck with your decision. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
