Home > Technical > CBs and setting up
Page 2 of 3 <123>
T1G UP
what about on the front bumper or the rear door? i'd like a CB but Tims one i borrowed was next to useless at the weekend.
Post #127516 28th Feb 2012 7:03pm
If you don't want to drill, try one of these, though I'd ask if it will suit a later wheel carrier, I'm not sure if it does?
http://www.ebay.co.uk/itm/Lr-Defender-seri...822wt_1327
Post #127522 28th Feb 2012 7:34pm
v40mav
ditch cb and get decent radios Very Happy
Seriously - I use amateur but I know that's not everyones choice. PMR is also a good choice
a few options that I have used in the past.
1 get the midland 42 hand held - a fantastic radio for close chat - i.e. in a convoy no need for external antenna
similar to what was said with magnets - I cut a small steel plate and glued this to the inside of the roof - was easy to get under the roof lining - and just used a load of grab adhesive. - used a 4" square plate - cut from an old steel shelf - was only about a couple of mil thick. - cheap easy fix
It allows you to use a mag mount
Another one that I personally didn't use but one of the other guys did - was to have a single roof bar - think it was a thule ole and mounted the antenna to that -
Hope this helps Defender 110 County SW
Disco 3 HSE
Freelander 2 HSE - SOLD going back to a car
www.lothian4x4response.org
Post #127526 28th Feb 2012 7:37pm
Licensed or 'freeband? Whistle
Sorry to offend!
Post #127529 28th Feb 2012 7:44pm
Laurie
Sorry to offend!
Not much use unless all your friends have one.
Post #127535 28th Feb 2012 8:04pm
ZeDefender
I'm fitting a CB aerial to split between CB (upcoming birthday present to self Whistle ) and FM. Until now I'd only thought about replacing my crappy FM aerial on the wing-top but 1.4 metres of steel sticking up is a bit "inconvenient" in car parks.
You may have just solved my problem Thumbs Up
Matt Tell someone you love them today because life is short.
Post #127545 28th Feb 2012 8:52pm
TJ101
Thats what i lent Tig,, who recons its was useless
But has worked on previous occasions ?? Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #127554 28th Feb 2012 9:16pm
T1G UP
It was picking up alot of interference from the 110 itself. Weird as it made the wipers move! could hear you sometimes and not others. Would like on like that for laning etc....
Post #127556 28th Feb 2012 9:21pm
walfy
When I had my PUMA I ran an extra earth cable from the base of the ant to a suitable earth point just inside the rear door. That way it kept the earth cable as short as possible, the ant was mounted just above the back door BTW 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #127557 28th Feb 2012 9:30pm
v40mav
Sorry to offend!
Very Happy
Amateur - formally licensed - and yes you need all others to be the same to use - but on numerous occasions this has been the best compared to CB and / PMR -
For PMR - I was referring to using PMR446 - but decent kit not the cheap 2 way walks you get in some places.
professional PMR units like Entel HT446 - works great -
I found the midland great when I used it - I found it better with the 12v power pack and the sep antenna rather than the rubber duck one that was with it - Defender 110 County SW
Disco 3 HSE
Post #127559 28th Feb 2012 9:44pm
BigRuss wrote:
Top tip
Make sure you have the CB setup for the right region that you in! Whistle
You'd be really silly not to check that first Bow down
Post #127560 28th Feb 2012 9:46pm
That sounds like an earth fault on the vehicle rather than a failing of the radio. I've also got a Midland 42 and find it to be excellent. Darren
Post #127571 28th Feb 2012 10:02pm
T1G UP
Possibly? only 2500 miles old and all systems are OK. Never had a CB before so could of been operator error but It was set up for me to use.
Post #127579 28th Feb 2012 10:19pm
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
I have a Midland 42 handheld wired in to the 90 as and when needed in much the same way as a moble unit would be, with a plug in mic'/speaker too.
With the rubber duck aerial it was fine for around 1/2 a mile or so, but I fitted an external aerial which can now get out and receive at least 5 miles.
I went for the 42 as I could use it on batteries in my Series II with the rubber duck and not having to worry about the positive earth. As there's no roof on her I expect the signal to go well past the 1/2 mile as mentioned above inside the 90 with the rubber duck aerial.
A word about handheld PMR.
Firstly, even the cheap handset pairs from places such as Aldi work well and well past their advertised 300m range, as mine did when we tested them, however, mindfull of the law concerning the use of mobiles without hands free, I asked a police officer mate of mine regarding the use of handheld pmr's and he said it was a no no in the same vane as a mobile.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #127945 1st Mar 2012 11:48am
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Chris.
Not strictly true.... it is not illegal to use radios/cbs when driving. The legislators were very careful to make it just phones and simialr GSM products. For some reason Airwave sets (Plod radio) are not included in the ban either.
The radio user will still come under the old 'not in proper control' as the phone users did up in unilt December '03, but there is a burden of proof that hey were in someway unable to control the vehicle...
I use an Icom IC-F4029SDR PMR radio, that has a removeable mic attached, and have driven past loads of plod while using it.. Had a few looks, but not been pulled.. Unlike my number plates, but that's another story!
Yaesu FT-817DN being installed in the cubby this weekend.. 1.8Mhz to 430Mhz!! Very Happy ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #128135 1st Mar 2012 11:30pm
Page 2 of 3 <123>
