Home > Puma (Tdci) > Gap door/window
Page 2 of 2 <12
Grockle
XS Pete wrote:
Quote:
same on ours doesn't cause any problems
Only that you're getting unnecessary water inside the door.
Pete
your not as there is a lip which the strip sits on, the water will get in at each end anyway 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #127399 28th Feb 2012 12:10pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Didn't realise that. Lets hope it's well painted inside there then!
Pete
Post #127412 28th Feb 2012 1:22pm
ZeDefender
I think the fewer nooks and crannies the water can sit, the fewer places that will rust. If it has to drain, then better just at the corners and straight down. That's why I'll fill the middle section in... Tell someone you love them today because life is short.
Post #127417 28th Feb 2012 1:32pm
Zagato
I have sealed my corners and on members motors, it can still get in but not so much and only when it rains heavily Wink Some have been done at the factory where they thumb in Dum Dum Wink but not very well Rolling Eyes Black window non hardening sealant again before you ask Matt Laughing Thumbs Up
Post #127491 28th Feb 2012 5:57pm
Caterham
mines the same - rubber not wide enough..... or should I be saying due to the poor qa and excessive tolerances in the manufacture of the door the rubber strip won't fit as intended.....
should I ask for a new door Very Happy
Post #127548 28th Feb 2012 8:57pm
ZeDefender
Are you a gambling man Question
Of course - I have it ready and waiting Thumbs Up
Incidentally, are there many vehicles designed to trap water coming off the windows in a gutter and then channel it to soak the steel inside the doors? Rolling Eyes Tell someone you love them today because life is short.
Post #127549 28th Feb 2012 9:02pm
Caterham
Embarassed
the dealers are going to love me.....
new door please.....and while you're at it - new seats (paint rusting / flaking off)
head light bezels (rusting)
mud flap brakets (rusting)
oh and perhaps they can have another look at the drivers lock that sticks closed when cold.
Big Cry
Post #127612 29th Feb 2012 7:22am
Zagato
Rust issues on a Defender are really something you will have to address yourself. They can replace most of it out but it will only happen again unless you treat it yourself....you will have to anyway when the warranty runs out.
Once the new parts have been replaced, treat it all and you won't have any problems. Some parts can be changed for SS parts like the bezels for a permanent solution of course Thumbs Up
Post #127614 29th Feb 2012 7:36am
Caterham
thanks (I'm just being lazy) - any suggestions on the seat frames tho?
I plan to send you a pm soon (that could be a few days tho till I get round to it) Thumbs Up
Post #127615 29th Feb 2012 7:44am
ZeDefender
Buy a decent firm seat that's well-designed and doesn't Censored up your back on long journeys (okay - that's probably just my problem) or rub down, treat and/or Hammerite the rusty bits or cover up with sticky-back plastic (if it's good enough for Blue Peter...) Tell someone you love them today because life is short.
Post #127620 29th Feb 2012 7:55am
Zagato
Are the seats rusting on the weld points or is it on the actual tubing and brackets. If it is localised on welds I would rub down, acid convert with Ku-Rust or similar then paint. If it is more widespread it depends how good you are with painting/masking./spraying etc! Otherwise it's back to the dealer who will probably send it off to be done but I would stay with the vehicle and make sure they do it properly Shocked Rolling Eyes
A lot of the metal on these motors isn't undercoated properly or at all Rolling Eyes All good fun for the DIYer Whistle
Post #127624 29th Feb 2012 8:07am
ZeDefender
Have you had much success with Ku-Rust? Tell someone you love them today because life is short.
Post #127625 29th Feb 2012 8:15am
Zagato
Yes it stops it dead. It only does surface rust though (fine for seat frame rust!) so need to wire brush, shot/sand/soda blast etc most of the rust off or for smaller parts dip in one of the rsut stripping solutions. Plenty of other products which are the same and can be used in a more bulk capacity although I did two axles and other bits with one small pot of Ku-rust with POR-15 over the top, Sorted for good Very Happy
Post #127631 29th Feb 2012 9:28am
ZeDefender
Cheers Thumbs Up Tell someone you love them today because life is short.
Post #127643 29th Feb 2012 10:16am
Page 2 of 2 <12
