Home > Puma (Tdci) > Puma Suspension - SOLVED
Page 2 of 2 <12
T1G UP
rear 90 HD spring are the same diametre as the front of a 110. I have a set waiting in the wings
Post #127166 27th Feb 2012 6:00pm
wslr
Tim: Thanks for the offer. I may drop in later this week if I get a moment.
Blackwolf: Lifting the Puma was not something I wanted to do, but every spring option other than Genuine Part offers one unfortunately. Looks like the Aussies have found out the Puma issue relating to drivetrain and front propshaft and I'd agree with what you have said, except that I've removed the Land Rover bumper and replaced it with an ARB type roo bar which is heavier than the original Land Rover bumper. It has also shifted the weight further forward by about 15cm, which may be the cause of the issue I have. The vehicle definitely drives differently and although it doesn't look too low today, the front end feels very different from how it did with the original set up.
The Aussie forums are full of this issue relating to fitting an ARB/TJM roo bar and winch, so I will probably fit the 130/110HD front springs later this week and see what happens.
Post #127256 27th Feb 2012 9:10pm
wslr
Right, Got a moment today to get the 110HD springs fitted and the difference is like chalk and cheese. The balance is perfect on the road. Job done. Very Happy
Before average height: 860mm (from floor to wheel arch)
After average height: 905mm (from floor to wheel arch)
Post #130101 9th Mar 2012 4:18pm
interesting thread, thanks for the update - nice when it all works out Thumbs Up
Post #130241 10th Mar 2012 7:06am
Projectblue
wslr - can you confirm which product you fitted? Was it gen LR part or a third party, and if 3rd party which ones?
Thanks
Post #130999 13th Mar 2012 12:44pm
wslr
Brand new Genuine Parts.
You'll find that one spring is slightly longer than the other, but once fitted, you'd never know - either by looking at it or driving it. Logic is that the springs are matched to the existing dampers, so rather than try and take an alternative and mess it up, I went Genuine. Cheapish as well.
Post #131005 13th Mar 2012 1:28pm
Page 2 of 2 <12
