Home > Technical > Ultra Gauge
Page 2 of 2 <12
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I'm not 100% sure but when the Smart was poorly it was a P0702 fault, which I was able to identify from the Internet as a transmission control system electrical fault, which I traced to chafed wiring (getting wet)
I guess the only way to really know is to create a known fault and see what happens, if that's possible.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #124665 17th Feb 2012 9:02am
mermoto
This looks like another interesting option, look forward to a review Thumbs Up
Mermoto
Post #124729 17th Feb 2012 4:29pm
Lorryman100
Received the gauge today, not a bad service as I ordered it on Thursday from the states.
It comes with a window sucker which is far too long for a defender but would fit a eurobox with no issues.
Up against the scangauge the Ultra gauge is a lot smaller and thinner comparatively but lacks the option of a removable connecting cable and the scangauges 2 connection sockets (side and rear).
I only had a brief play with the UG in the Puma, as I will need to route the cable behind the dash before I leave it in for testing. I won't be using the supplied window mount either, as I mounted the scangauge onto an old sat nav mount that I had cut down to size. I then applied adhesive velcro onto the mount and the scangauge and have already applied the relevant velcro side to the UG and it fits well onto the scangauges window mount.
I did have a quick scroll through the options and gauge screens (There are 8, all user programmable), and noticed straight away the addition of a couple of gauges that the scangauge doesn't monitor, MAF g/s and Torque in newtons. There are also user settable Alarm functions for all the sensors monitored. I had a play with the coolant alarm and had it set to go off at 10C (Ambient air today was 6C), so I started the Puma and once 10C was registered in the coolant temp it started bleeping and a warning message scrolled onto the screen. I will fit it and have a play tomorrow and do a comparison with the scangauge on functions and abilities and then I'll do a write up and add it into the diagnostics for a Puma post I did. Thumbs Up
List of gauges that the UG can read. Not all specific to a Diesel though Whistle
Brian.
Post #125457 20th Feb 2012 7:40pm
The Boy
Lookig forward to your feedback
Post #125463 20th Feb 2012 7:54pm
MartinK
I tried to download the user manual but it didn't work...So I can't RTFM, and wondered if anyone knew...:
Would the Ultra Gauge also wind in and out and reset the Electronic Parking Brake (EPB) on other OBD vehicles (I'm thinking of my XC70)... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #125536 21st Feb 2012 7:13am
d j hutton
I was able to reset a transmission fault on a smart car so don't see why not.
DJ 1989 200tdi 90 csw
Buy British 🇬🇧
Post #125556 21st Feb 2012 9:12am
Lorryman100
No, it is just a gauge tool that can read and reset generic fault codes. You would need a Volvo compliant diagnostic tool to do what you are after.
Link to the manual (EM version): http://ultra-gauge.com/ultragauge/support/...anuals.htm
Post #125626 21st Feb 2012 3:24pm
d j hutton
I think I misunderstood the wind in and out bit! Should/will reset a fault code though. 1989 200tdi 90 csw
Buy British 🇬🇧
Post #125732 21st Feb 2012 8:39pm
Lorryman100
Received an invoice for £19.08 from FedEx in the post. £9.08 VAT and £10 handling charge. Just paid it over the phone using their Censored automated service, want to bet I get a bill reminder in the next week or two? Whistle
Post #127085 27th Feb 2012 1:56pm
The Boy
Waiting for mine. 10 quid handling charge Mad
Post #127091 27th Feb 2012 2:06pm
Eduardo
Looks like a good alternative at an affordable price.
Can the system store values or is just showing and dissapear?
I'm thinking in analyze the problem with the power loss
Thanks Eduardo
Post #127124 27th Feb 2012 3:44pm
Lorryman100
Eduardo,
It just shows the gauge data and doesn't offer any data storage. The one main difference between this and the scangauge I have noticed, is that the UG refreshes the sensor information a lot more often than the scangauge does.
Post #127145 27th Feb 2012 4:37pm
Page 2 of 2 <12
