Home > Puma (Tdci) > fitted new speakers and aaarrgh ! |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
(note to self...google alestorm)
Ahem, where were we? Oh yeah, I did the same, did that, waisted money! Buy a nice head unit, and fit some bigger speakers somehwere, if you can, squeeze an amp and sub in somewhere |
2nd Feb 2012 10:41pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Could be a dodgy lead or connection between the ipod and the head unit, or could be a dodgy ipod. I repaired an ipod for someone over Christmas with a similar fault. There was a broken joint on the tiny board which the headphone socket is mounted to. You could make it work sometimes by wiggling the lead.
Pete |
2nd Feb 2012 10:48pm |
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 |
Check the balance (left and right) to see that nothing has been changed, I've done it too many time where I jump to the conclusion that it's broken, when in fact it's just that the settings are wrong. Also take out and plug back in the audio aux lead, when it isn't in properly or doesn't have it the whole way in then it can just play out into one side of speakers.
Is a pity it hasn't turned out well for you, I changed all mine to alpine 10cm's and apart from an overlap in the plastic edging to the standard speaker cover it fits fine and works beautifully, only issue I had was the rear lighting loom part got in the way of the left rear speaker on my 90 so had to fasten it up with cable ties. I do find that the standard Stereo is not the most reliable, I changed mine after it refused to give me back my CD displaying an error code so ripped the out and put in a Bluetooth Sony one which is much better. Good luck =================================== Steve 90 xs sw in Stonoway Grey - Sold 110 USW X-TECH |
2nd Feb 2012 10:58pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
As the others have said
Start with the Head Unit with a Decent Amp unless you want to have an exteral Amp if so buy a corsa My Route was Change front speakers to Focal High & Mids HU is a Kenwood Media player no CD so the units is not as deep more room behind for wires I have a 110 so I made some rear boxes and installed 6*9 oval Focal Mid & Low Installed an Active Sub (Focal) proper size not an under the seat job I will in time up the speaker wires but the sound puts most of the Gary boys to Shame |
3rd Feb 2012 6:34am |
I have the same issue when I plug my CB into the aux channel; the problem is it's a mono plug, double check the plug and lead.
HTH bp |
3rd Feb 2012 7:23am |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
Are you certain the polarity of the speakers was right? That might account for the rubbish tinny quality. Easy mistake. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
3rd Feb 2012 11:00am |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
Alpine all the way!!!!!!
Head unit and sub, but I stayed with alpine 4'' speakers. They put out plenty!!! Didnt wana retrofit bigger speakers. |
3rd Feb 2012 11:53am |
E20STU Member Since: 17 Apr 2011 Location: Buckinghamshire Posts: 26 |
I too upgraded the head unit with an Alpine, put in a sub and stayed with the original speakers. Once done I found the original speakers sounded ok and could handle a reasonable amount of volume once you'd taken the bass away from them.
Stu |
3rd Feb 2012 12:26pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
thanks everyone
RRUK I thought at first it might be the polarity as the LR speakers are not marked but usually the narrower of the two connectors is the negative one so I followed that arrangement Looks like I might have to spend some cash on a head unit then. Thanks for the suggestions all |
3rd Feb 2012 9:23pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20453 |
You can very easily check the positive and negative using a multimeter Voltage setting That's what I did with mine anyway:
Click image to enlarge Click image to enlarge |
3rd Feb 2012 10:11pm |
I've got a multimeter somewhere but I wouldn't have a clue as to how to check which terminals are + or -. How exactly do you do that konabikes if thats not too dim a question ?
3rd Feb 2012 11:06pm |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
If its a digital multimeter, put the red and black leads from the meter into the speaker connections, dosent matter which one or which way around, just put one lead in one connection and one lead in the other.
Put meter on DC volts (if scaled under 50V should be fine) If you get -4.4V (for instance) your the wrong way around - i.e. your black wire is + and your red wire is - or vice a versa. If your meter is analogue, and its the wrong way around, the needle will try to go the otherway, reverse the leads and your there. |
4th Feb 2012 8:21am |
thanks Paul I'll try that
4th Feb 2012 9:01am |
As Paul above said. Quite simply I would have thought negative - would give no reading at all. positive + should. And also make sure radio is on and playing something
4th Feb 2012 11:11am |
