Re: Corrosion Block
cobs wrote:
Also came across this at the boat show recently - bought some but haven't tried it in anger yet - not sure if it's made by the same people as ACF50 or just same importer.
I've been using it on my boat and now use it on the Puma. Whenever I take out bolts that were previously coated in the stuff, they are still corrosion free and the grease is still soft and malleable.
OOOhhh do you think the Corrosion Block grease would be good to prevent (or reduce the risk of) bimetallic corrosion? i.e. stainless door hinge bolts...???? Instead of Duralac?Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
