Home > Technical > Recharging dual batteries?
Page 2 of 3 <123>
bolampau
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
My hangover has subsided so I went to check out the National Luna dual monitor and it showed the main battery as only 12v.
Took off the seat and plugged the Ctek croc clips onto the main battery and switched charger to AGM cycle.
N.B. the ignition is off.
Now the monitor is showing that both batteries are charging, which I did not expect? I thought it would only charge the main battery.......how come it can do both?
Sorry if my question sounds dumb but I'm clueless about electrickery.
Thanks in advance,
Paul
Post #120885 3rd Feb 2012 2:14pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
As BPMan wrote
Quote:
if the ctek pushes more than 13.8v, then the battery management system should control the charging of both batteries - because the VSR will join them
So the nat luna battery monitor joins the batteries as the main one has full voltage (more than 13.somethingV)
If i remember correctly you can set the trigger voltage on this system but then you have to open it up, void your warrantee and find the right resistor. Too long ago to remember how it looked inside.
Its a typical problem with this unit (set for classic batteries) and the higher voltage of AGM batteries, i had the same issue with my discovery and dual optima's before.
Can leave you with 2 half batteries after connecting the c-tek. Well, should be sorted after about 60 hours of charging as then both will be full again.
Would recommend you to put a manual switch between the batteries so you can isolate them when charging.
2cents
Smile
Post #120972 3rd Feb 2012 6:27pm
Thanks in advance,
Paul
Paul - the national luma battery management system is doing what it is supposed to do, it will manage the charging of the batteries for you. To be honest, why not run the truck for a few weeks, keeping an eye on the NL display showing the state of the batteries? These battery management systems are very good, currently other forum members are in extreme cold temperatures in the arctic circle running the same system as you and as far as we can tell they are fine. whoever owned your truck before you knew what they were doing. most of us just have a single battery and run fine. enjoy your truck!
bp
Post #120985 3rd Feb 2012 6:40pm
bolampau
2cents
Smile
Thanks BPMan,
the charger has now finished, it took 7 hours roughly. After disconnecting the Ctek, the dual monitor shows both batteries as above the normal mark now - it's too dark to read the exact voltage.
The car started up straight away and all seems well.
I think I'm gonna fit the Ctek standard lead to the main battery and trail the connector outside the seat box. Then I won't have to lift the seat base to do a recharge in future!
Cheers,
Paul
Post #121071 3rd Feb 2012 8:47pm
bolampau
2cents
Smile
Thanks BPMan,
Cheers,
Paul
Apologies, as I didn't thank Tetra805 for his advice!
Post #121074 3rd Feb 2012 8:50pm
my 110 has not been started since before december, but I bet it will be fine tomorrow morning (with a single battery)
it's been on the ctek since last saturday Thumbs Up
Post #121083 3rd Feb 2012 9:22pm
K9F
bpman wrote:
my 110 has not been started since before december, but I bet it will be fine tomorrow morning (with a single battery) it's been on the ctek since last saturday Thumbs Up
SHOCK!!!! HORROR!!!! "Hold the front page!" Steve you're not!! You can't!! What will the neighbours say?
The 110s not being dug out surely? Don't believe it, refuse to look and see if there's an answer! Someone else is bound to start a new thread if you do!
Rolling with laughter Bow down Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #121107 3rd Feb 2012 10:55pm
are you taking the p!55 Mal ?
Post #121127 4th Feb 2012 6:29am
K9F
Embarassed Maybe an incy wincy bit I am! Laughing I've only seen it twice, thought you may have been hiring it on an hourly basis! Laughing Whip it out, wave it about and show it off! Defender Ice too!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #121159 4th Feb 2012 9:26am
leeds
Well BP Ice has experienced some light Yorkshire snow today. Ice looks cool Thumbs Up
Brendan
Post #121222 4th Feb 2012 2:49pm
BigRuss
Brendan
He didn't get lost then Whistle Russell
2011MY 110 XS USW Black
Post #121224 4th Feb 2012 2:53pm
leeds
Well let's just say he made it ok, although it was an interesting route he took. He did manage to explore one of our local green lanes on his way, so not exactly the fastest route. He did mention something about his sat nav.
Brendan
Post #121226 4th Feb 2012 3:18pm
BigRuss
Brendan
WHAT! He popped the ICE's cherry Thud ? I don't believe you. Russell
Post #121229 4th Feb 2012 3:30pm
BigRuss wrote:
Brendan
i've been off roading in the ice in france Shocked
Post #121276 4th Feb 2012 7:04pm
all back now, ice ready to be de-tented tomorrow.. great minds are thinking about how to do this
snowed all the way from Brendan's to home ... no hold ups except for sh!troen drivers as usual.
just going to sort out the pics ...
Post #121277 4th Feb 2012 7:06pm
Page 2 of 3 <123>
