![]() | Home > Maintenance & Modifications > I have had enough! |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Make sure the rubber grommets for the left hand drive wipers are sealed too.
Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
water can track in via the rear washer pipes were they come through the bulk head,access via n/s speaker as previously posted by me. 2.4 90 XS
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 ![]() ![]() ![]() |
Don't worry the water leaks may pale into insignificance once the other dealer issues take over, in my experience if you can live with it for three years they tend to be fully sorted.
I always enjoy doing my longer trips in the 'loaner' cars to keep my mileage down. |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Get them to take off the fake hinge and re seal them and take the drain plugs out of the heater intake there are 2 you will have to feel around for them.
Appreciate your frustration....Maybe the solution lies in the myriad of other 'wet carpet' threads of which there are indeed quite a few....
![]() htttp://www.defender2.net/forum/topic9549.html?highlight=carpets http://www.defender2.net/forum/topic2126.html?highlight=carpets http://www.defender2.net/forum/topic10440.html?highlight=carpets http://www.defender2.net/forum/topic10278.html?highlight=carpets http://www.defender2.net/forum/topic8883.html?highlight=carpets http://www.defender2.net/forum/topic1334.html?highlight=carpets http://www.defender2.net/forum/topic4254.html?highlight=carpets http://www.defender2.net/forum/topic2920.html?highlight=carpets http://www.defender2.net/forum/topic1549.html?highlight=carpets If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
In my experience, the windscreen leaks are the worst. You don't really notice them but they build up somewhere behind the dash then flood the floor. Zagato's cure of pumping windscreen sealant (something like Arbomast) all around the rubber to frame (especially the top) worked for me. The problem was water coming forward off the roof (rain or melting snow) and into the top seal, then running down around inside the seal and exiting front of dash. It was a slow process, but after a few day's rain it built up to a waterfall. Most people say the windscreen seal is prehistoric rubbish (on mine, the crappy welding made a dry seal impossible).
Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Snowbeast17 Member Since: 20 Nov 2011 Location: Highlands Posts: 48 ![]() ![]() ![]() |
I noticed there is water lying in the channel on the inside where the wipers are. But also the drain on the outside has two joins on it not far from the hinges. I kept an eye on them inside the cab while my dad poured water on it, after a couple of watering cans later the water started coming through and would run down on to the bulk head seal, which then absorbed it until it was soaking, it was then dripping on to the footwell. I can't decide if the bolts on the hinge is letting in water or if it's just running of the bulk head seal. Thanks guys for your advice, it's always good to hear other people's ideas and experiences with these things. RRS tdv8 08 Disco 3 HSE 57 Defender 90 xs 06 All gone |
