Home > Td5 > Urgent help needed please re fuel pump wiring
Arbman Al
I have been waiting for a chassis loom to arrive to connect the fuel pump up, but it has not appeared. I needed to sort out the ecu etc today, so can I run 4 wires from the fuel pump to the connector block on the dash loom?
Will this work, or are their other conmnections needed?
Cheers....Al 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #116411 18th Jan 2012 9:14am
You only need 2 wires to make the pump operate.... the other 2 are for the fuel level sender.
where the chassis loom comes up under the bonnet, you'll have 3 plugs... an orange (i think), a white or grey, and a 2 pin oval shaped one. the oval shaped is the fuel pump feed.
Fairly beefy wires, but off the top of my head I'm not sure which way they go around.... you could undo the fuel feed pipe off the engine and then turn the ing on, see if fuel pumps out... if not then it's wired backwards!
Post #116486 18th Jan 2012 2:52pm
Arbman Al
Cheers Jamie,
Figured that out in the end, and once I realised there should be a 12v supply to the starter motor (doh) she fired up!
Got an electrical problem somewhere as when I connect the battery the headlights came on and the switch is off, indicators don't work and the wipers won't turn off! 1996 Defender 130 converted to TD5 and auto
Post #116494 18th Jan 2012 3:54pm
Martin
Site Admin
'cos I'm nice:
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #116519 18th Jan 2012 4:49pm
