Home > Off Topic > Memory Map 2012
Page 1 of 4 1234>
Memory Map 2012
Has anyone got memory map on their iPhone ?
I've just upgraded and have a 5 device license, all the marketing info. states it will run on an iphone, but the iStore says it's not available in my country. checked country = uk Shocked
Post #114831 13th Jan 2012 7:29am
Lookers Park Royal
I've got MM on my iPhone but not the 2012 version. Do you want me to check my settings etc?
James Thumbs Up
Post #114843 13th Jan 2012 8:22am
TJ101
Yep, also on a I phone as well as I Pad,,
Works well on both,, but not the latest version Whistle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #114861 13th Jan 2012 9:10am
thanks guys, please could you confirm the country you have set in the itunes account ?
Post #114867 13th Jan 2012 9:27am
Lookers Park Royal
I'll check when I get home, but deffo UK as my brother-in-law was trying to explain the virtures of his US iTunes account (re early releases etc) however he has to buy prepaid USD vouchers.
James Thumbs Up
Post #114883 13th Jan 2012 10:14am
TJ101
Ditto to James,, Steve,, all on the home machine !! but sure its a UK account ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #114886 13th Jan 2012 10:22am
RRUK
WTF is a Memory Map?
I'm on iOS5 and don't have this...I think Shocked 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #114893 13th Jan 2012 10:36am
Buzz
2010 Defender 110 Puma 2.4 DCPU Tonga Green
OS based navigational software. Very good.
I use it and ViewRanger on iPad and iPhone.
Post #114900 13th Jan 2012 10:43am
racer111
My brother has it but on an ipad, its meant to be really good and its definitely a UK account, sounds a bit weird why you could get it on an ipad and not the phone?
Check out zalando where I bought expensive red shoes
Post #114901 13th Jan 2012 10:47am
I have mm2004 on my laptop and tablet, but there was/is an offer to upgrade to mm2012 so i bit the bullet and upgraded. i should be able to install on my iphone but itunes tells me it is not available in my country. i checked my account, might try and contact apple to see if there is a problem with my account.
so thanks for all the replies, and I'll keep the thread updated with any new findings
Post #114933 13th Jan 2012 12:10pm
TJ101
Hope i am not stating the obvious Steve!!
I have my MM on loads of devises, home PC, 2 tough-books, as well as the i phone and Pad
I am guessing you have bought the app via i Tunes ??
Then just load your maps from the PC, to the MM app in i tunes, then loads all to the phone and pad via the sync California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #114946 13th Jan 2012 12:38pm
thanks Tim, this is what i did ...
from laptop, run itunes, logon to store and search for memory map app ... a message "application not available in your area" is displayed ...
i have logged onto my account and checked the country, address and all looks ok
i tried to search for memory map from my iphone .. memory map not found
not sure what else to try ?
Post #114958 13th Jan 2012 12:52pm
coln18
I have the complete set of Great Britain memory map which i use on the lap top for my trekking and hill walking, i just print of the map i need for a particular walk and off i go, i didnt know you could transfer them onto portable devices.
Is it just iphones or is there an app for putting it onto an android phone?
Col
Post #115050 13th Jan 2012 5:25pm
I've just tried again...
if i search the istore memory-map does not appear in the results
if i go to the memory-map web site, and select iphone, it redirects me to istore but then i get the following message
"Your request could not be completed." and "The item you've requested is not currently available in the UK store".
I checked, I'm UK based and the message eludes to "UK" so I don't know ....
Post #115053 13th Jan 2012 5:28pm
if someone's got a minute, please could you try to see if memory-map is available in itunes store UK and let me know ?
Post #115105 13th Jan 2012 6:30pm
Page 1 of 4 1234>
