Home > Puma (Tdci) > Essential Parts |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 |
For my trip across the Simpson Desert in Australia I put together a spares bag with the following:
Brake Pads (Sets for Front and Rear) Wheel Bearing set, including a selection of shims Uni Joints, one each for each prop shaft Vac pump and gasket Fan belt Fuel Filters (x2) Air Filters (x2) Wheel Nuts (x5) Spare "Mega" Fuses Drive Flange and Gaskets Sealant Engine Oil, (can be used as PAS fluid and in the gearbox in an emergency) EP90 Selection of nuts/bolts/screws and gasket paper Electrical wire, crimp fittings, tape, fuses, lamps. Selection of hose clamps Emergency Repair Tape/Glue/"Metal" putty. Tools/fire extinguisher/first aid kit
We must have it backwards over here, (might have something to do with being in the southern hemisphere?), but the only vehicles that had breakdowns on our trip was the Land Crusiers! |
14th Jan 2012 12:38am |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 |
Please, can you provide more info about the xfer box recall ? Thanks ! |
14th Jan 2012 4:31am |
I'm also interested in the "essential parts" list because next summer I will try to do a 3 weeks trip in Morocco. I'm looking for help about where to buy a Vac Pump at cheaper price. The original spare part in fairly expensive... |
14th Jan 2012 4:39am |
surf110 Member Since: 14 Jan 2008 Location: Rio de Janeiro Posts: 43 |
Thanks guys. Great suggestions. Keep them coming.
If you have part number, please include those as well. |
23rd Jan 2012 6:53pm |
