Home > Maintenance & Modifications > I fancy something diffent |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 712 |
Sounds intresting. Does it sound like a TD5? How can you spot a 5 cylinder Transit?
11th Jan 2012 9:45pm |
noogles Member Since: 07 Feb 2011 Location: Brunei Posts: 34 |
I've been toying around with the idea of a Lexus v8 1uzfe. I hear they're quite cheap and pretty bulletproof.
12th Jan 2012 7:46am |
WHY? Broken with Hybrid??? but yes 5 cylinder tdci..3.2 200 hp out of the box not need to change the gearbox.... ...at the beginning as well..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
12th Jan 2012 8:29am |
http://www.ebay.co.uk/itm/TRANSIT-3-2-TDCI...1c2293ccf3
http://www.ebay.co.uk/itm/TRANSIT-ENGINE-3...3f0fb5f6cf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
12th Jan 2012 1:08pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
I haven't broken anything just as I mainly run 35inch simex I want more power a lot more for off roading Mybtruck has run fine with the turbo Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
12th Jan 2012 7:29pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
I like the idea of the 5 cylinder, larger engine lower EGT's and off boost torque. Nearer to the 3.9 Isusu CKD kits assembled here.
13th Jan 2012 4:43am |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 |
I have a friend at Ricardo's who did the original engine work for Land Rover and also did all the ecu designs on the transit.
I remember him saying that Land Rover had to do quite a lot of modifications to the 2.4 from standard. I seem to think he said a standard transit engine has a bunch of sensors in the engine that land rover had to remove as they sucked water in when submerged especially when the engine is hot. Don't Land Rover make a fuss about oil scavenging in the 2.4 at extreme angles? I personally would go the TDV6 because at least you know these same issues have been thought about for the D3. |
13th Jan 2012 7:40am |
Ok well surely all the switches and wiring are very similar so it wouldn't be hard to change these ?!?
13th Jan 2012 2:22pm |
Way of life Member Since: 07 Sep 2015 Location: Halifax NS Posts: 22 |
How did this build go?
I'm wanting to do the 3.2 into my Defender 2.4 just don't have what I like......power. The 3.2 is on this side of the pond now but all the crap on it I want the UK/EU one. Did you do the build can I ask you cost in real money. |
28th Jan 2016 3:50am |
