![]() | Home > Td5 > Td5 Diesel in coolant |
TDfive Member Since: 02 Sep 2008 Location: somerset Posts: 51 ![]() ![]() ![]() |
welcome mate ![]() cant help with the problem but know a guy thats good with um will ask him when i next speak to he ![]() 05 110 crew cab td5 1987 90 tc TD/200TDI DISCO CONVERTION ![]() |
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 ![]() ![]() |
Hi, I have not heard of any other way diesel can get in the coolant other than the fuel cooler (& this is rare).
Cracked heads leaking diesel into the sump is slightly more common (still infrequent), or O rings on the injectors leaking fuel back up into the head (thus draining into the sump) more common. Regards Steve |
Ratty Member Since: 19 Mar 2009 Location: Somerset Posts: 37 ![]() ![]() |
Thanks Steve. ![]() I haven't heard of it myself but I just want to make sure that it's the residue left over from the blown fuel cooler that I can smell. ![]() |
just to update the thread in case it helps anyone else in the future, the reason for the diesel in the coolant is a crack in the fuel rail in the head. I'm currently on the lookout for a replacement cylinder head.
