Home > Off Topic > Heads Up - wifi cracked.
pom
If you use wifi that has a pre-shared pin code (sky, bt, etc) whereby you press a button on the router and then enter the pin code on your laptop etc. Be aware this has been cracked.
Not too great an issue if your at home and nextdoor aren't using your connection for suspect downloads but definitely disable this if you want to be 100% safe. These home boxes shouldn't be used in a business environment so not such an issue but if in doubt disable it.
Pom
Post #110558 29th Dec 2011 12:45pm
Had issues over Xmas with my BT Business Hub and was advised that I should disable my BT openzone thing if I didnt need it
Post #110561 29th Dec 2011 12:49pm
