Home > My Defender > should I go for a pair of JWS 8700's ?
Page 3 of 7 <1234567>
ericvv
When it really snows the snow also does not melt on my standard SVX H4 units. These halogens get warmer, but not warm enough to keep them snow free. Also have to get out from time to time to wipe them clear. Think only cars with headlamp washers can really remove snow. This is not so bad as the side mirrors constantly freezing up when it is cold and a bit humid, much more annoying.
Post #109258 22nd Dec 2011 8:19pm
maybe a coating of rainX or polished meths would make the lens more slippery ?
are they glass or plastic / polycarbon lenses ?
Post #109261 22nd Dec 2011 8:24pm
ericvv
pretty sure glass........ same as on your ICE Thumbs Up
Post #109262 22nd Dec 2011 8:27pm
hopefully I'll have these installed by the time I visit AutoBritt for the service, we're going to visit the motor show too Thumbs Up
Post #109267 22nd Dec 2011 8:40pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I've been looking at getting LED headlights, but is it true that from 2012 vehicles fitted with HID or LED headlights will need self leveling lamps/suspension & washers for the MOT?
Post #109288 22nd Dec 2011 10:04pm
BigRuss
bpman wrote:
mine does not come out in bad weather Rolling with laughter
Is bad really the right term Question
Is it not more of any weather that isn't sunny, blue sky's and dry Whistle Russell
2011MY 110 XS USW Black
Post #109295 22nd Dec 2011 10:40pm
yes, no rust provoking weather (+55)
Post #109297 22nd Dec 2011 10:42pm
BigRuss
Rolling with laughter Rolling with laughter Rolling with laughter
Well I have just been told and I quote "do you want them, if so just wait until I'm working" Russell
Post #109298 22nd Dec 2011 10:44pm
happy days Thumbs Up
Post #109299 22nd Dec 2011 10:47pm
Alive Tuning
Lots of questions to answer, so here we go...
The headlights are fully ECE approved for all functions, high & low beam, and front position light (sidelight).
The headlights are available as LHD (EU) or RHD (UK) specifications. Headlamp deflectors could be used when using UK spec lamps in Europe, but since the beam pattern is so clean and focused, chances are they won't dazzle anyway.
Snow clearing – the JWS LED headlights will clear snow and ice. I think down to minus 20 deg c from memory.
These lamps have a poly-carbonate lens, and are shallow in depth, so they will fit most motorcycles too.
2012 MOT & LED: Washing & levelling is not required for JWS LED headlights fitted to Defender as the luminous flux is below the threshold where this is mandatory.
There is no legal HID conversion / kit in existence for the Defender irrespective of levelling or washing being fitted or not.
HID reading in it’s most simplified form: http://www2.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps.html
Post #109306 22nd Dec 2011 10:58pm
ericvv
Thanks, all clear answers by Alive. Now what is left is that I better try to get those units (pre)approved by our local SAN (presume similar as your MOT) here in Switzeland. Something for beginning next year, will first discuss with the local LR dealer here how best to approach that. One more question for Alive Tuning, if before approaching our SAN I would like to get full info of technical specs, including light output, etc. for these LED units, you probably can provide those, yes?
Tks, and happy holidays, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #109320 23rd Dec 2011 5:05am
This may help (but its the non side light one)
https://www.defender2.net/gallery/albums/u...-round.pdf
Post #109322 23rd Dec 2011 6:21am
ericvv
Post #109323 23rd Dec 2011 6:30am
unpredictable yes but a great place for Winter tyre testing (Les Diablerets)
Post #109324 23rd Dec 2011 7:09am
dgardel
Italy
But the main external screen is glass (very robust due to the MIL specs.)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #109333 23rd Dec 2011 9:08am
