![]() | Home > Td5 > coolant loss problem |
george130 Member Since: 14 Aug 2007 Location: Australia Posts: 20 ![]() ![]() |
If you have bleed the system properly then it's not a good sign. I would recommend getting the coolant tested for a blown head.
wally Member Since: 26 Aug 2007 Location: Bauple, Q Posts: 4 ![]() ![]() |
Yes that's what I've been suspecting for some time. I was hoping that somebody might come up with something that's a little cheaper to remedy. 1996 single cab 130
1999 Td5 D2 |
Get a pressure check and also have coolant chemically tested for exhaust gas. This will at least help.
