Home > For Sale & Wanted > [SORTED] Cable tie base mounts x6 |
I need 6 of these cable tie mounts, just 6... Not 100 or 200...
By chance does anyone have a bag of these and wouldn't miss 6 of them?? https://www.amazon.co.uk/gp/product/B07ZKN...&psc=1 These little bases: Many thanks Last edited by geobloke on 13th Jul 2023 8:29am. Edited 1 time in total |
10th Jul 2023 12:52pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1997 |
If no one has any for you B and Q do in 25’s for a couple of quid.
10th Jul 2023 1:29pm |
Thanks Ian I did not know they did them. The nearest BandQ to me is about 45 mins away, living in the boon-docks has its down sides
10th Jul 2023 1:32pm |
Thanks Phill. I really should have said These are going behind the bumper in the void to fix the cabling to the DRL/fog lights so have to be screwed down and not made just to rust at the first experience of Welsh weather.
Do you think there is enough material in your bases to drill out? |
10th Jul 2023 3:30pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
I bought some of these recently in small/sensible quantities from either 12Voltplanet, or autoelectricalsupplies.... or something like that. If it's still something you need then let me know and I can try and pin down the website. Donald
1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
10th Jul 2023 3:45pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2037 |
I have some, they look the same size as your Amazon link.
I slid a 4.8mm cable tie through it a moment ago. Click image to enlarge Send me your postal address and will get them on the way to you asap. |
10th Jul 2023 3:49pm |
Essex is a long way away from here, but I could kiss you Daz...
That is exactly what I am after. PM on the way. |
10th Jul 2023 3:54pm |
It’s Sussex actually, bit posher than Essex.
No problem, will get them posted. |
10th Jul 2023 3:58pm |
Oh well if it is Sussex then I'd take you to dinner (somewhere posh of course) first, then kiss you
10th Jul 2023 4:00pm |
Sounds good to me.
10th Jul 2023 4:07pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
If you do not mind drilling, then another option is to drill 2 holes, 10mm (or less) apart, and then pass a cable tie through the holes such that the cable tie clamps the wire. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
10th Jul 2023 4:11pm |
Hurtful |
10th Jul 2023 6:23pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2084 |
But true?
10th Jul 2023 6:38pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 500 |
Too late now, but for anyone else looking -
https://www.polevolt.co.uk/acatalog/Cable_Ties___Fixings.html Cable Tie Cradle small 4.8mm. Fixing hole 3.8mm. 10 pack. Ref: CTC1/10 Cable Tie Cradle large 7.8mm. Fixing hole 5.0mm. 10 pack. Ref: CTC2/10 Also - https://www.autoelectricsupplies.co.uk/product/335/category/65 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
10th Jul 2023 9:12pm |
