Home > Puma (Tdci) > Defender 2.4 puma Canbus
Puma2.custom
France 2007 Defender 110 Puma 2.4 SW Keswick Green
Hi there guys! New member here. Been a multiple defender, 101 and jag owner for a long time but only just joined the forum. Currently working on completely restoring a puma 110 with an unfortunate past. While doing so I need a new cluster. I was thinking of making a custom plug and play one with a full hd lcd display(not a small undertaking but not uncommon for me to take on such projects). For this I will need to read out the canbus of the 2.4 ecu to know what canbus signals im working with. Now since the only 2.4 puma I have is in bits, I just wanted to check/ask if anyone here might be able to help me along.
I will need to know the following canbus high and low signals from the ecu:
Engine Rpm
Engine temp
Engine warning Light
Oil pressure light
Additional signals not from ECU and not canbus:
Speed
Fuel level
ABS light
Difflock
High/Low range
If anyone has any info on even only a couple it would be greatly appreciated!
(don't worry about persuading me not to do any of this)
Post #988390 9th Apr 2023 6:40pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
I have also been considering something similar. No idea where to start. Have been investigating a raspberry pi screen with a ups and power on/board.
No idea where to get the data feeds except direct from the OBD socket? 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #988412 9th Apr 2023 10:07pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I came across this project on GitHub.
https://github.com/posmanet/DeCANder
Could be of some help?
Post #988429 10th Apr 2023 7:30am
Landowner
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
I have a small meter (Autol X60) ic. Just plug into he odb. It displays all the can items you mention including speed (as far as I remember) great little tool.
Post #988436 10th Apr 2023 8:33am
