Home > Puma (Tdci) > Lost Drive
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Lost Drive
Took the Puma out of winter mothball and went for a drive today, it was very clunky and as I was passing Town & Country 4x4 it lost all drive, sounded like it was jumping splines but the gearbox was appeared fine.
Couldn’t have found a better place to breakdown, just a few minutes and the T&C lads came out to push me back to their place…. Big Cry
Better get the smart car back out to meet the dog walkers…. Dog
 Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #988093 6th Apr 2023 5:55am
hornet
Sorry to hear that, you will need TUD500020
Post #988095 6th Apr 2023 6:53am
LR90XS2011
assuming it is the adaptor shaft replace with ASHCROFT, IRB or LOF improved arrangement, I have ASHCROFT and its outlasted 2 originals so far, however it could just be a drive shaft flange DEFENDER 90 TDCI XS,
Post #988096 6th Apr 2023 6:56am
Leamreject
Agreed, if it is there is no point in fitting an OE one so I will try to get hold of the LOF extreme kit Thumbs Up Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #988102 6th Apr 2023 7:31am
Usually a loss of drive with scary noises is either the gearbox output adaptor shaft (mentioned above) or a rear axle drive flange. The easy way to check is to engage the centre diff lock and establish if drive is restored. If it is, the problem is a drive flange (and you can carefully continue your journey). If you still have scary noises instead of motion it will be the adaptor shaft and you'll need recovery.
When doing the diff lock test do make sure that it's genuinely engaged, they can stick if not used periodically, so check the light comes on. An alternative test, not requiring the CDL, is to get someone to look underneath the vehicle at the propshafts as you try to drive. If a propshaft is turning, it's a drive flange (or halfshaft or diff) which has failed. If neither propshaft is turning, it's the adaptor shaft (or clutch, gearbox, or transfer box) which has failed.
Post #988108 6th Apr 2023 8:08am
Dinnu
A lot to read on this thread: https://www.defender2.net/forum/topic59735.html
But do make sure that the transfer box has not jumped out of gear. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #988148 6th Apr 2023 3:58pm
