Home > Td5 > TD5 judders... like a kangaroo
Page 2 of 3 <123>
Rivarama
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Quick update… after a week without using the car - I took it to go pick the kids up at school (they asked me to do so this morning when they left the house Smile
The flywheel started to make quite a bit of noise when I pulled out of my driveway (uphill) and applying some gas. The noise was like a growl and could be heard in both clutched / declutched position. At some point the gear lever was vibrating too.
After a few turns and gear changes with frank accelerations, the noise got better and was only noticeable when the clutch was being used.
The car is now definitely louder when driving through the gears… a deep growl coming from the gearbox/flywheel area.
Not sure whether that’s the source of the original judders, but I definitely need to get a new clutch/flywheel kit.
After a bit of research, looks like the LOF Power SMF clutch kit is the way to go.
Thoughts?
Post #981165 3rd Feb 2023 9:09pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I remedied mine with a lof power spec with single mass flywheel and after the truck was smoother than its ever been.
Post #981168 3rd Feb 2023 9:17pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
I have the LOF SMF kit, it's great on my truck for handling the extra power from my tuned TD5, but the downside for me is its noisier and there's a noticeable resonance point around 2000 rpm where it throbs like an old washing machine TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #981185 3rd Feb 2023 11:54pm
Rivarama
Interesting I had never heard that before.
May I ask what people recommend between a DMF and SMF?
I use the car mainly to get the dog and family around as a week end car with the occasional lanes, and will do 4-5 proper off-roading trips a year.
I might also get a stage 1 upgrade on my engine too eventually.
Post #981285 4th Feb 2023 8:41pm
TexasRover
One benefit of the solid flywheel is that it lasts longer and it is cheaper to buy.
However how many miles are you realistically going to do. Most defenders are no long working vehicles and are mainly used recreational, sounds like yours is. This is mosl likely going to the last flywheel replacement on your car during your ownership.
On the cost side, how does the cost difference compare to the installation cost ( or effort ). For a little bit more overall cost you enjoy more comfort.
Unless you are running your Landrover on a tight budget I would go for the dual mass option
Post #981311 5th Feb 2023 7:45am
Rivarama
Texasrover - I agree 100% with your comment.
I am not trying to scrape a few ££ but was asking what clutch is the best.
Everyone swears by LOF Clutches for their durability and build quality. They only seem to be building SMF kits and they are more expensive than any DMF I can find.
I seem to read that most people seem to recommend against DMF as many seem to go wrong early. I don’t want to change mine again anytime soon and would be very happy to spend more now.
So before spending £600 on their SMF clutch kit, I wanted to make sure that’s the right one for me.
Post #981315 5th Feb 2023 8:23am
ibexman
Opps
Post #981321 5th Feb 2023 9:13am
ibexman
DMF all day OE 👍
Post #981322 5th Feb 2023 9:14am
It's very difficult to make a satisfactory sprung driven plate suitable for a modern high-revving diesel engine, hence the popularity of the DMF, and incidentally the significant problems LR had with the sprung clutch in the TDCi. It hasn't been helped by the fact that LR seems to have forgotten how to design or select a clutch of any kind.
The TD5 DMF is great when it is in good condition but is relatively short-lived, very prone to judder, expensive to replace, and really doesn't like being driven like a torquey truck diesel (it doesn't like being engaged at very low engine speeds, the DMF springs seem unable to cope).
The Puma clutch was truly awful in the early years and still isn't great, but the latest versions are probably more satisfactory than the TD5 DMF, at least in my opinion, and is much better suited to the characteristics of the TDCi engine. The downside is that you will ALWAYS get much more chatter in neutral and more resonance noise and effects with this type of clutch in a high-revving modern diesel than you will with a DMF, and this is something which is unacceptable to many.
It is worth bearing in mind that there is a reason why JLR binned the DMF for the Puma/MT82 installation, after all the Transit (except 4x4) uses a DMF for the same combo.
Post #981334 5th Feb 2023 10:23am
andy2111
SMF is definitely recommend if you have or plan to have a tuned engine.
LOF offer a range of heavy duty clutches that will work with the standard Valeo flywheel. TD5 hardtop to Puma inspired Poptop - my build thread
Post #981338 5th Feb 2023 10:58am
ibexman
I think I read somewhere the DMF was used for the imbalance of the 5 cylinder engine 🤔
Post #981344 5th Feb 2023 11:40am
One of the joys of a 5-cylinder engine is that there should be minimal imbalance, far less than on a 4.
Post #981350 5th Feb 2023 12:21pm
Dinnu
5 cylinders on a 4 stroke engine means that there is an overlap of the firing stroke. That makes the need for a DMF less than say a 4 cylinder. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #981351 5th Feb 2023 12:35pm
ibexman
Sorry I spoke ,I’ll leave it to you experts 🙈😂
Post #981352 5th Feb 2023 12:39pm
kenzle8a
I’ve done about 15k now on my lof power spec and smf, no complaints at all. I also tow well over 3 tones every weekend In the summer and it’s been fine.
Post #981374 5th Feb 2023 3:16pm
Page 2 of 3 <123>
