Home > Puma (Tdci) > Non-starter |
AndyS Member Since: 18 Aug 2012 Location: London Posts: 595 |
I think I hammered the starter so hard it gave up. I drained two batteries in about 30 minutes, recharged both overnight and did it again the following day. I thought the batteries weren't holding their full charge because the starter was getting slower and slower. I was connecting both batteries to give it extra oomph which makes for a lot of power.
Now the old starter is off you can tell that's where the smell is coming from, it stinks. I've totally burnt it out which is probably why the fuse blew. I think the reason why the car wouldn't start was because the glow plugs were old and knackered so I've over stressed the starter and killed that. Luckily I got the mechanic to change the glow plugs while he was there so if they're still not working it'll also be a fuse or relay. |
15th Jan 2023 3:10pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2002 |
Your right, I misconstrued the original message, thinking the mechanic had done the job and then the OP drove it and it failed. |
15th Jan 2023 10:14pm |
Quick update (for people who search this in the future)...
Car started instantly this morning, -8⁰c in London and the coldest night since 1987 according to the wireless. So I'm declaring it fixed and will assume it was the glow plugs causing a cold start issue which stressed the starter motor, burning it out (the weird electrical smell), drained the battery and blew the mega fuse. All now replaced and working.i Which was the point of the update, not just working well it's running really really well. It's the most lively it's felt in a long time. Parts cost me about £350 (battery, starter, glow plugs x4 and mega fuse) and the mechanic charged me £140 to fit the starter and plugs. If your car is getting a bit reluctant to start, around,100k miles and 12 years old it's worth replacing these bits. Thanks everyone. |
23rd Jan 2023 1:53pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
Curiously I have also just fitted a new battery and a new starter, due to my long-standing intermittent failure-to-crank problem seeming to get a bit worse. The original motor and battery were from 2007 and have been on the vehicle for 260k miles.
The new battery and starter does seem to have transformed the starting experience in a very positive way so far. |
23rd Jan 2023 7:02pm |
