Home > Puma (Tdci) > Heated Windscreen Switch = No Light |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 678 |
I suspect you need the engine running, relay will take alternator voltage signal. 130 Puma HCPU with an Artica 240LR Demountable Camper
2nd Jan 2023 5:29pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 821 |
I believe it only works with the engine running. 2008 2.4 110 Utility Station Wagon XS.
2nd Jan 2023 5:50pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
As above, the HFW requires the engine to be running in order to work. The is.an "engine running" signal from the IPAC which is used for this purpose (which if I remember is actually dependent upon the alternator providing an output which means the engine is running).
Start your engine and repeat your test, let s know how you get on. |
2nd Jan 2023 5:55pm |
nick.bw Member Since: 26 Oct 2020 Location: Essex Posts: 72 |
Cheers chaps
Engine running and still no joy Engine running. Switch pressed. No light on HWS button |
2nd Jan 2023 6:44pm |
Is it factory-fitted or aftermarket?
2nd Jan 2023 8:16pm |
KISSMYAURA Member Since: 13 Jan 2018 Location: KENT Posts: 45 |
factory spec?
2nd Jan 2023 8:35pm |
Yeah. Factory fitted
2nd Jan 2023 8:36pm |
is it working, just no switch light? or all DOA?
2nd Jan 2023 9:05pm |
Completely dead. Not working at ll
3rd Jan 2023 9:28am |
is the relay clicking?
3rd Jan 2023 9:33am |
No. Nothing when the button is pressed. Switched the relays around as well to test and nothing
Click image to enlarge Could be the realy OR the timer... |
3rd Jan 2023 9:35am |
The switch light (AKA tell tail) is wired to the timer, so if the timer is duff you will not get a light oin the switch, the realy may still work but the timer may not be actuating!
3rd Jan 2023 9:36am |
Awesome, thanks. Need to see if i can find a spare one to test.
Thansk |
3rd Jan 2023 9:38am |
