Home > Puma (Tdci) > Big puddle problem |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Gear change getting clunky - related with the wiring for the clutch switch, so yes I expect this to be an earthing problem. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
26th Oct 2022 2:22pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Clunky gearing is because the ECU thinks you're not moving. The gearchange is horrid without the speed being supplied to the ECU (via the instrument pack).
If you lose only the speedo and RPM/coolant temp etc still work then yes I think you have water ingress into the speedo transducer connector or the transducer itself. Martin 1988 90 Td5 NAS soft top 2015 D90 XS SW |
26th Oct 2022 2:26pm |
Ronniebee Member Since: 12 Oct 2015 Location: U.K. Posts: 31 |
Thanks Martin, I’ll start with the connection and take it from there.
26th Oct 2022 5:37pm |
