Home > In Car Electronics > Solar MPPT controller - who's fixed it where?
donmacn
Hi folks,
I have a 300Tdi, so the 'battery box' is the compartment under the passenger seat.
I'm considering a portable/suitcase type solar system as an 'off grid' top-up option if needed, mainly to run a fridge and keep the beer cool.
I understand that an MPPT controller is the thing to use - more efficient panel output - but when looking into one brand it said something along the lines of: the controller will turn unused charge/current into heat, and that it should be mounted in a well-ventilated area with 9" of clearance all round.
I had been hoping to fit this into the battery box, but with two batteries it's a little cramped in there. I might find space to fit the controller (they're a bit bigger than I anticipated) but I certainly won't find the 9" clearance, and it's not especially well ventilated. On the other hand the box is a YRM alu. version, and aluminium is a good heat sink.
So for those who've done this, where have you put the controller? If in the seat box has it survived/suffered?
I usually try and search first, and did this time, but couldn't find any info.
ta. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #968105 17th Oct 2022 9:24pm
Bill1919
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
I put both the controller in the battery box under the seat, but had to make a new battery tray so every would fit.
 1988 110 csw 2.5Td (19J) (gone)
1992 110 csw Tdi200 (gone)
1995 110 csw Tdi300 (gone)
2015 110 XS csw 2.2 puma
Post #968113 18th Oct 2022 12:30am
donmacn
Hi Bill,
Thanks for that - that's even more cramped than mine! Your batteries are a bit larger, but against my transmission tunnel I have my accessory relay and fuse installation.
Is yours a mppt controller? Have you had no issues with heat generation? Donald
in the past..
Post #968116 18th Oct 2022 7:15am
Bill1919
Yes, it is a CTEX DC-DC MPPT controller. I fitted it about 3 years ago, no problems with heat. 1988 110 csw 2.5Td (19J) (gone)
Post #968118 18th Oct 2022 7:36am
geobloke
Curious to know. What does MPPT stand for? Rolling Eyes
Post #968119 18th Oct 2022 7:58am
Maximum Power Point Tracking. Basically, solar panel output varies with temperature and these controllers make the best of what's available, giving an advantage of approx. 25-30% over earlier controller types. Darren
Post #968120 18th Oct 2022 8:25am
geobloke
LRA you are indeed an anorak, but definitely my kind of anorak Thumbs Up Thumbs Up
Post #968131 18th Oct 2022 10:09am
donmacn
^^ I knew that too! Does that make me an apprentice anorak?? Very Happy
Thanks Bill - I guess it's a case of manufacturers covering themselves. Donald
in the past..
Post #968134 18th Oct 2022 10:20am
geobloke
Donald I do feel your signature now requires the addition of the post-nominal A-A Thumbs Up
A-A (Apprentice Anorak)
Post #968137 18th Oct 2022 10:45am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Yeah.
1x John Deere 110 amp batt
1x AMG 100 amp
And that CTEC charger fit all well in my battery box
And one cable coming out connecting the 120 W foldable solar panel adjustable towards sun light.
1st Installation takes about 90 min. Just mind all the required fuses !
Post #969562 31st Oct 2022 6:56pm
