Home > Maintenance & Modifications > Advice needed: Transfer case
Page 2 of 2 <12
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
true, However on a positive, it's actually cheaper this way... Smile 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #959649 26th Jul 2022 11:26pm
geobloke
And as if Mike has been reading this thread... He released this video this morning... More useful info on why the LT230 leaks and his fixes
https://youtu.be/AuDkBg5604o
FYI he really isn't a million miles from you, at least on the same continent. Could be worth dropping him a line if you just want to chat with someone. Thumbs Up
Post #959683 27th Jul 2022 9:41am
spudfan
Ireland
1992 Defender 110 200 tdi 188,000 miles still on it's origional LT 230.
Was there not a time when people took diffs and transfer boxes from the Discovery and fitted them to the Defender. It did raise the over all gearing even in low range. The Discovery started with the 200 tdi.
OOPs checking back I see this has already being mentioned Rolling Eyes 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #959686 27th Jul 2022 9:46am
htb2
Wales
05 Defender TD5 on original transfer box at 250K here.
Discovery and defender diff ratios are the same at 3.54, it was series land rovers people were fitting range rover diffs into to raise the gearing.
Post #959690 27th Jul 2022 10:02am
spudfan
Ireland
"Discovery and defender diff ratios are the same at 3.54, it was series land rovers people were fitting range rover diffs into to raise the gearing."
I always thought the Discovery diffs were slightly higher in ratio. My mistake and am happy to be corrected. You indeed learn something every day Thumbs Up 1982 88" 2.25 diesel
Post #959691 27th Jul 2022 10:05am
Page 2 of 2 <12
