Home > Puma (Tdci) > getting my ecu, 10as alarm and instrument cluster checked
Sam smith
United Kingdom 2009 Defender 110 Puma 2.4 HT Epsom Green
Hi
is there anywhere i can send my ecu, 10as alarm and instrument cluster to to get checked over for issues and paired together.
many thanks!
Post #956584 26th Jun 2022 10:24am
Ianh
i suspect the easiest and cheapest option is to have them in the vehicle when trying to validate them doing their individual jobs and working together collectively.
But to confirm this you could reach out to Pete at bell auto services as he may well be able to do it https://bellautoservices.co.uk/
Or pm Martin on here , for sure he can do the instrument cluster.
Note :-if your ECU is not the original for the engine / vehicle you have it will need to be checked to see if it will work with your engine / vehicle setup and if it is it will need to have the correct software build installed and configured to your specific engine / vehicle setup. I think that will be the biggest job.
Remote key can check 10AS units https://remotekey.co.uk/land-rover-keys-re...larm-ecus/
Technozen can also check 10AS units https://www.technozen-electronics.co.uk/la...-services/
And a nanocom or GAP diagnostics IID tool can link the 3 components together.
Post #956585 26th Jun 2022 11:06am
Sam smith
yes that is the issue i think as i assume the ecu isnt original as it had donor written on which may be the source of my issues.
so the ecu - presumed non original
alarm ecu not original to the vehicle
instrument cluster- believed original not sure if working fully though
a right headache..
any ideas if there is anyone who can link and pair all 3?
i have a nanocom but its not letting me synchronise the alarm and im getting a wide variety of fault codes
Post #956587 26th Jun 2022 11:53am
Ianh
Give Pete at bell auto services a call, explain the situation and I’m sure he will be able to advise on the best course of action, whether he is able to assist, and any associated costs.
Post #956599 26th Jun 2022 6:11pm
