Home > Puma (Tdci) > Engine mounts |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1833 |
You could try Bearmach.
https://www.bearmach.com/product/engine-mo...0/KKB10260 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
24th Jun 2022 8:42am |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Thanks, I forget about Bearmach because I have never used them. I guess I'll give them a try... Roaming around 🇳🇴🇨đź‡
24th Jun 2022 9:17am |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
I’ve read before that some aftermarket engine mounts are very hard and also create vibration even if new. I can’t remember where I read it, but the strong advice was to go for original which have the right amount of give in them. If I can find the info I will post it…
Please let us know how you get on because I have this on my to do list! |
25th Jun 2022 7:36am |
I found the article.. it’s about a series vehicle, but is saying get your parts from Land Rover if possible as even OEM labelled stuff may not be the right spec. He implies the Bearmach parts are good. Hope this helps!
http://www.nickslandrover.co.uk/new-engine-mounts-cure-vibration/ https://forums.lr4x4.com/topic/88426-new-e...vibration/ |
25th Jun 2022 7:42am |
Turner engineering have first class reputation for remanufactured Landy engines and they also sell engine mounts
https://www.turnerengineering.co.uk/kkb500...2x28714507 |
25th Jun 2022 8:36am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
This is very true for older mounts, up to 200tdi. I did order an aftermarket set, hard as rock for my 88 90. Ordered genuine, so pliable. What a difference. But how aftermarket Td5 and later mounts feel like I have no idea. Bit of a gamble. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
25th Jun 2022 11:20am |
I’ve ordered the Bearmach ones, they will arrive Monday. The Genuine LR mounts are out of stock at JLR Classics and I’ve asked to be notified when back in stock.
I do have one supplier who says his supplier has the “genuine” mounts in stock and he can order them. But this same supplier also sent me “genuine” drive flanges that arrived in a Br**part box. So yeah, it’s hard to know what you’re getting. I’ll let you guys know how it goes Roaming around 🇳🇴🇨🇠|
25th Jun 2022 11:55am |
